- First Name
- Erik
- Sep 28, 2021
- Rhode Island
- Jeep renegade desert hawk
- Engine
- 2.0L EcoBoost
Sorry for the long post but I thought this was a good project to share. I completed my installation of aftermarket seat heaters to the front seats that I mentioned on a previous thread.
The kit was from Amazon, I can’t find the order in my history but this is the closest match in price and product.
Driver or Passenger Top Replacement Heater Heating Element https://a.co/d/4dBFfnK
I think I paid $48.
Total time for the installation was about 5 1/2 hours. I chipped away at it over the past couple months. The seat bottoms took about an hour each and the backs took about 1 1/2 hours. Running the wiring from the seats to the fuses took 1/2 hour. The rest of the time was figuring out hour to tap into power and location of the switches. I hope these pictures are clear.
these 1st 2 pics show the beginning of the bottoms. There are plastic clips that fold on themselves under the front and sides.
At each of the indented seams on the seats, there are plastic channels held to the base by metal rings called hog rings. It was recommended to use hog ring pliers but I used regular pliers and it worked ok:
After the rings were removed, I was able to pull back the rest of the way and install the pads. I made slices in the pads where the hog rings would re-attach. I did have to cut these a little.
the wires were easy enough to tuck under both sides of the center console to run to the fuse panel on the passenger side footboard. I found a ground on the right side when removed the glove compartment:
then the power, I found these 2 10 amp fuses that are only on with the truck or accessories.
I tried to use regular fuse taps like these:
Micro2 Blade Fuse Holder Fuse with 10A, 20A Fuse - Tap 12V Car Add-a-Circuit Fuse TAP Adapter with Micro2 Blade Fuse (2 Sets) https://a.co/d/iDhngxu
But they would not fit in the spot in between 2 of the larger fuses in the 2nd pic, so I found these 10 amp pigtail fuses.
When using the pigtail, you must determine which side of the fuse is the power side. There are plenty of tutorials online. Then it was on to the switches, I chose the lower panel on either side of the 12 volt outlet. I think they fit well.
I think I paid $48.
