If it’s the lube idiot they’re the ones that often forget to put oil in forget to tighten drain pan plug forget to tighten oil filter.You would think it's pretty straight forward to download a new software to the vehicle right? Unless they are inputting wrong information about the vehicle, I don't see how they could mess this up
Until your MCU fails and bricks most of the functionality of the vehicle. Having a single point of failure has its own downsides.I hate to throw out Tesla here (NOT a Tesla fanboy), but they pointed the way. Centralized, over-the-air updates. Slowly but surely killing all those little computers in favor of zonal or even centralized computing. Own all the software yourself. It's the only path that leads to sanity.
Thanks for the details and your vibration under load exactly matches what I am experiencing with gas engine running and uphills is much worse. I guess my next question is will the new set last longer than 10k miles?Ford put a pause on 23E09. That pause has now been cleared (as of Friday March 22).
At some point there must have been some fault in the updated software.... my 22 Hybrid XLT had the update in mid-January. I haven't had any issues...and I haven't heard of anyone w/ issues from January updates. So it was likely a later update than mine that cause the issue.
It looks to me like Ford thinks that they have solved the software issue. I think that reupdating all of the modules involved in that recall should solve the problem for most people.
There may have been similar issues w/ other PCM update recalls (like 23P18).
At any rate, have your service dept see if there is a PCM update available for your Maverick. Hopefully that will solve the issue!
Vibration on acceleration may be the CV joint in axles. That was the case w/ mine. I had vibration under load. Especially uphill. Only when ICE running. Both front axles replaced solved the issues for me. Driver side CV joint was worse than passenger side.
Amen. Getting built by the UAW will not necessarily translate to a trouble free life time vehicle. I think the bigger problem is all the off shore Chinese made parts that are flooding our shelves nowadays.If it were built in America it wouldn't have higher quality, just be more expensive.
Vehicles are built to specs. The fact that Ford is the most recalled brand in America 3 years in a row speaks volumes to how well those specs are followed by suppliers and Ford themselves. And they're working very, very hard at being top dog for the 4th year as well.
It appears that also the 23E07 Software calibration update, or 23E09 Reprogram powertrain control module are causing this issue with 2022 builds. I would wait until the engine/power shut off issue is corrected. My VIN# also does not require these two updates.Do you have the 23E07 Software calibration update, or 23E09 Reprogram powertrain control module? My 2023 Lariat Hybrid (built 12/22) has both of these listed with a "remedy not yet available" note. But I'm considering never getting it done even if available.
Just had an issue along that line with a Toyota steering angle sensor. Once the steering angle sensor goes out-of-range one time, the chip in the sensor bricks itself and returns a permanent reading of -850.5 degrees.A gazillion decentralized controllers, each with their own software (not written or owned by Ford), communicating over a dated automotive bus. So update one, and then cross your fingers they all still work together.
