HSBII
Sam
2017 Super Duty 2024 Maverick
Last month when I did my Gentex mirror install I noticed that there was no glove box light I cant recall the last vehicle I owned that did not have one heck even my 70 Pinto had one back in the day..
None the less I decided if Ford was to cheap to install one I would so it was off to the wrecking yard in search of a donor... Found lots of options and snagged several choices but ended up with all the needed components from a 98 BMW 740..
The light assembly, the switch, their associated plugs and as much of the wiring as I could cut without to much work..
Ford Maverick Glove box light for your Maverick... DIY How-To Writeup IMG_3244
Next with all the necessary components in hand it was time to start figuring out where to install them.. Decided to center the light in the glove box frame so I taped it off and laid out the lights dimensions on the back / inside portion on the frame... Started by drilling the corners with a 1/8'' hole and tried to use a model craft saw but the plastic was to sticky?? so I ended up using a utility knife with a new blade...
Ford Maverick Glove box light for your Maverick... DIY How-To Writeup IMG_3168
Ford Maverick Glove box light for your Maverick... DIY How-To Writeup IMG_3171
Ford Maverick Glove box light for your Maverick... DIY How-To Writeup IMG_3172
Ford Maverick Glove box light for your Maverick... DIY How-To Writeup IMG_3173
Ford Maverick Glove box light for your Maverick... DIY How-To Writeup IMG_3174
Next was the switch location did not really want to see the switch so I installed it in the lower left portion of the frame...
Ford Maverick Glove box light for your Maverick... DIY How-To Writeup IMG_3176
Ford Maverick Glove box light for your Maverick... DIY How-To Writeup IMG_3178
Ford Maverick Glove box light for your Maverick... DIY How-To Writeup IMG_3179
Ford Maverick Glove box light for your Maverick... DIY How-To Writeup IMG_3180
Built my wiring harness with the pigtail / plugs I removed from the BMW and laced it out on the frame and installed light and switch...
Ford Maverick Glove box light for your Maverick... DIY How-To Writeup IMG_3221
Ford Maverick Glove box light for your Maverick... DIY How-To Writeup IMG_3218
Gave it a bench test just just because...
Ford Maverick Glove box light for your Maverick... DIY How-To Writeup IMG_3220
Now it was a matter of just reinstalling the frame and glove box back in the truck and completing the wiring by taping the positive lead into fuse #20 with a add a fuse tap and grounding the negative to the BCM mounting lug
Ford Maverick Glove box light for your Maverick... DIY How-To Writeup IMG_3230 power
Ford Maverick Glove box light for your Maverick... DIY How-To Writeup IMG_3238
Ford Maverick Glove box light for your Maverick... DIY How-To Writeup IMG_3241
Looks like a factory install to me and the wife well she'll like it too............
Mike215
Bucks County, PA
22 Ford Maverick XLT Hybrid
Nicely done.
EONR24
Swag
United States
2024 Ford Maverick XL
Well done. I essentially did the same thing for ambient lighting under the radio in my XL!
JPinPA
Jay
Stewartstown PA
2024 Maverick XLT
There are a number of different styles of fuse taps. Which one did you used here?
Edge Haley
Edge
CARBONDALE-Atlanta
PORSCHE
Well done, looks professional. I did this fix the cheap & easy way, week of delivery - 01-04-2022 with a stick-on night light. 2 1/2 yrs and little AA battery still working since I rarely open the Glove Box. Little night-lights are all over Amazon for $3-5 each.
JPinPA
Jay
Stewartstown PA
2024 Maverick XLT
Thanks! Looks like I’ll be junk yard picking soon!
HSBII
HSBII
Sam
I revised the fuse tap I used as I listed the wrong one its the micro fuse tap...
Dad
I'm with you on the disappointment of not having a glove box light for the Maverick. I decided to mount a small (about the same size as yours) rechargeable LED with touch on/off switch. I applaud you for moving ahead and doing this mod and for posting the how-to's. Here's the light I used for those who aren't so inclined to do the same undertaking as you.
PS: Nice job!
https://www.amazon.com/gp/product/B0B6HZ4X2Y/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Toddman45
St. Louis, MO
I plan to do this and one in the console as well.
CurtisB
2023 Maverick XLT Hybrid
Such a cool idea, one needs to put on sunglasses to experience the true thought of how well you did this! Truly amazing!!
Buyerfind
Pembroke Pines, Florida
'22 Hybrid Lariat,No Deletes,10/5/21 order 11/5/22
YOU ARE AN ABSOLUTE BEAST!! Very nice!
Alharm1
Alan
USA-WV
2024 Maverick Lariat Tremor
Good work!
