Get navigation on the 6.5" dash display?
commadorebob
Decayed
yes
a car
Gullzway
OK
1968 Ford Mustang Fastback
You just gave me a new hobby...
Same, had to get a new Forscan 2 month license. Will try later today. Coming back from a road trip now, would have been nice to try out.
Gullzway
OK
I'll have to hook up this evening to verify, but this looks correct from what I can remember. From the forscan message board. https://forscan.org/forum/viewtopic.php?f=16&t=13630&start=10
Thanks. Turned on the repeater/turn by turn from first screen and Repeater(Heads up display) options, worked. Waze seems a little slower than google maps, but only tested around the block.
Mine is a 2022 Lariat Lux.
Surprised I haven't seen this mentioned on the forum, or did I miss it somewhere?
Ford Maverick Get navigation on the 6.5" dash display? IMG20230804173930
Gullzway
OK
Pictures
shouldn’t need more than this.
You're right. I went back and turned off the repeater conformance option.
I could NOT get it to work with my iphone 13 mini(secondary phone) and Carplay.
I tried Google Maps, Waze, and Apple maps.
Odd that that thread just died off back in 2020.
Gullzway
OK
Something I've noticed, if I try to start a route in Waze, it will not show the direction prompts on the instrument screen.
I have to start a route in Google maps, then exit it and open Waze up and start a route, then it works.
Ford Maverick Get navigation on the 6.5" dash display? IMG20230805125100~2
Ford Maverick Get navigation on the 6.5" dash display? IMG20230805125343~2
cyberdog
Ray
2023 Maverick Lariat Hybrid
The turn/distance in the upper left of the 6.5 is automatic, my bone stock/un-modified Lariat w/Lux has shown the turn directions with distance in the upper left since day one when using the built in Sync3 Navigation. I fully plan to make some changes with Forscan, but just haven't gotten around to doing so. Hoping to to turn on TSR & Remote Window Up/Down next weekend, once I have some spare time to play with it.
Gullzway
OK
2022’s didn't have built in Sync3 Navigation.
commadorebob
I could be overlooking it, but I'm not seeing the APIM module. I see everything else.
justiz00
North America
If your obd2 module has an HS/MS switch, it may need to be switched to the other position, though, forscan should prompt you to put it in the correct position before proceeding.
commadorebob
I must be missing a setting or something.
Ford Maverick Get navigation on the 6.5" dash display? 1692123526237
