FX4 also has 3.81 gears - same as 4K Towing? Crazy theory?
Big Kahuna
WA
Someone on another group pointed out that the guy that helped design the truck - Klaus de Mello, Vehicle Engineering Manager - mentioned in a video that the FX4 also had the 3.81 gearing.
Anyone confirm or deny this claim? I thought only the 4K got the 3.81?
Portcqb
Eric
South Portland, ME
2025 Ford Maverick Lariat Hybrid AWD
The spec sheet only says 3.81 with 4k tow package, but that being said some FX4 will have 3.81 since they can have 4k package along with it.
Big Kahuna
Big Kahuna
WA
Is it possible the FX4 without the 4K would have the 3.81 and they just aren't mentioning it? Doesn't seem likely to me but this other guys seems to think so.
Portcqb
Eric
South Portland, ME
Anything is possible although if Ford was going to use the same gearing it would have made more sense for production to merge the fx4 and 4k packages.
tebowed
Ryan
Virginia
2022 Maverick Lariat FX4 2.0T
It would, but then they couldn't charge more money.
MavrickEcoBoost
2019 Ranger
Ford has separated the parts. So the Tow and the FX4 will not have the same Transaxle. So that would tell me it is different ratios.
Ford Maverick FX4 also has 3.81 gears - same as 4K Towing? Crazy theory? Screenshot 2021-10-08 140642
Probity
Covington LA
'24 Silverado CCSB 2.7 (a Mav. Hybrid next time?)
If you get the 2.0 EB AWD with FX4 (but not with 4K Tow Package) it will have a 3.63 final drive ratio, not a 3.81.
Ford Maverick FX4 also has 3.81 gears - same as 4K Towing? Crazy theory? 2022 towguide mav
Big Kahuna
Big Kahuna
WA
Could be they include the 3.81 in the FX4 to give more low end power for off roading vs the standard AWD? Just continuing the hypothesis. I fully believe they don't but it's an interesting idea.
MavrickEcoBoost
2019 Ranger
If they did it would show it in this part break down. It would say LHD 4WD Tow Pack 1 and 4WD SP Pack
sherlockjones
michigan
Hello MaverickEcoBoost,
Im having trouble reading this, how do you know that the FX4 gets the lower gearing? Is there a code for it in this image?
D K
Portland
Colorado, M3, Corvette
The transaxle difference could just mean one gets an external oil cooler, one does not.
Look at the differences in F150 rear ends - you can get same ratios but different size ring gear (9.5 vs. 8.8 I believe).
MavrickEcoBoost
2019 Ranger
Everything that Ford has released shows 3.63. Including the image right below mine. The absolute only way to get 3.81 is to have the tow package included. The parts list shows that there are two separate Transaxles. One specifically for towing. That would confirm to me that FX4 is only cooling and skid plates. There is nothing that says they get any added axle support.
