Front End Vibration - Why?!
Sahpo
Blair, NE
2023 Ford Maverick
Rotated the tires which now have about 3500 miles on them. There were no issues prior to the rotation and balancing. They were balanced/rotated. They were balanced again and my 2023 XL 2.0T still vibrates. The vibration is felt through the steering wheel, which as I am told is a sign that the issue is with the front end. Has anyone experienced this? What might be the issue? In advance... Thanks much!
Steve,
Maybe CV joints / axles.
How many miles total?
edmc
Ted
Ohio
2026 Ford Maverick Lariat, 2020 Subaru WRX STI
Yea have you had CV's replaced? Fairly common issue pre 25. Lots of good info on here might have to try a few different search strings.
BK007
BK007
OH
How many Miles are on it.....?
Warped Rotors..
CV Axle..
Transmission Shudder....
Bad Tire..
Did not balance the tires right...
Bad Tire Shop...
..Lug Nuts -Torqued by Hand With a Torque Wrench?
Sway Bar End Link....
Build up on hub surface...
And the answer is...
Ford Maverick Front End Vibration - Why?! brakeexplodingGIF (2)
Mudduck
JD
Utah
24 Maverick FX4. '26 Toyota Sequoia TRD Pro. 72 VW Ghia
They still aren't balanced right.
Discount hooked me up with that same issue a few times. Now I go to Costco or the dealership. Dealership fixed me 2 of the 3 times after multiple trips to 3 different discount tire locations.
Joester
UPSTATE NY
2022 Maverick ECO, FX4, 4K, 2023 Bronco Sport, 2024 Escape Red Line
I guess I should knock on wood.
My '22 has 70K and rides smooth as can be. Never had issues. Only recalls.
stevj
Stev
Pacific Northwest
2026 Hybrid Maverick
Before you retorque those lug nuts, remove each front wheel and check for debris stuck to the wheel mounting surface or the hub.
If that's what's causing your vibration, no amount of lug nut torque will totally eliminate the vibration.
raceman94
Newnan, GA
2022 Maverick XLT
Having something similar with my truck after getting new tires...makes me wonder if Discount Tires doesn't know how to balance them correctly or something?
homerdog
Jack
St Johns, MI
2022 Maverick Lariat Hybrid
Mine is at the dealer getting repaired for that right now. However it was more of a wobble instead of a vibration. They're replacing the driver side drive axle. I took it in yesterday, parts minus the bolts or nuts came in today. Hopefully it's done tomorrow. They sent an email, saying they wanted $93 for a cabin air filter replacement :bandit: and $725 for the axle. I told them no on the filter and check the warranty/recall for the axle. The engine air filter they wanted $31 to replace so not tooooo ridiculous.
