Front Bumper Panel Gap
pwkno
United States
2022 Maverick XLT FX4
I took delivery of my Maverick a few weeks ago. The dealership had to remove the front bumper cover to replace the lower black fascia that they damaged by drilling holes for the license plate bracket in the wrong location. I noticed that the gap between the bumper cover and fender on the passenger side of the vehicle is uneven and not flush with the fender where it meets the headlight. I am looking to see if this is normal or could be a result of the bumper cover being reinstalled incorrectly. I did not notice whether it was like this from the factory or not before the bumper cover was removed. I checked the bolts inside the wheel well that hold the bumper cover on to the fender and they are tight. From looking at the way the bumper cover attaches, I do not see any way to adjust it. Definitely something I can live with if it's within spec, but I'm just concerned that something could have been installed incorrectly by the dealership.
Ford Maverick Front Bumper Panel Gap IMG_4315
Ford Maverick Front Bumper Panel Gap IMG_4319
Ford Maverick Front Bumper Panel Gap IMG_4320
MLowe05
GA
Definitely not re-installed correctly - and I am not surprised. Shoddy work by dealerships should be the expectation.
You should be able to correct this with basic tools.
Aherpa
Iowa
Edge, Maverick Lariat Hybrid
It looks like your dealer should be fixing this because it is definitely not right. . . it sticks out!
Good luck.
Dad
Good luck.
Agree. Shoddy workmanship.
pwkno
United States
Any idea how I can adjust it? Here is a picture of the bracket inside the wheel well. The bumper cover is held on by 3 bolts, not by clips like many cars, and there are 3 alignment pins that align the bumper cover bracket and the fender. I could take the whole assembly off and try to reinstall it, but I hate to do that more times than necessary, and I do not trust the dealer to not make it worse.
Ford Maverick Front Bumper Panel Gap IMG_4279
MLowe05
GA
You will probably want to remove it completely and reinstall it. Done correctly this should not cause an issue.
Aherpa
Iowa
You might just take it back to the dealership and ask them to fix it right. That way, they may treat you a little better in the future. Otherwise, you may just get more of the same. They know how to fix it.
Question;
In the upper left hand quadrant of the picture, is that a weld going around that downward facing tab, or is it glue?
pwkno
United States
Question;
If I’m looking at what I think you’re asking about, it is a weld. Definitely not glue.
Milous
WA State
2022 XLT Alto Blu, LUX, Sunroof, delivered 3/18/22
^^^ Agreed, that's what I would do.
pwkno
United States
I ended up removing the bumper cover and reinstalling it using the instructions in the service manual. I was careful to make sure all the clips engaged and torqued the bolts to spec, and it looks exactly the same as before I removed the cover. I think that's just how mine is and was probably like that from the factory and I just didn't notice. I think it's not unusual for vehicles in this price range, especially in the first model year, to have some uneven gaps. I'm guessing my passenger side fender is very slightly out of spec, or the molding of the bumper cover is very slightly off. I'm going to stop worrying about it. Certainly not noticeable enough for me to want anyone to try to adjust the fender or replace the bumper cover.
pwkno
United States
I had some time to examine how the vehicle is put together, and after looking carefully, I am fairly confident that the gap I am seeing is due to slight alignment differences between the driver side and passenger side fenders. Visually, there are some obvious differences in the gaps between different areas where the fender meets another panel on each side of the vehicle.
Driver side bottom of fender:
Ford Maverick Front Bumper Panel Gap driver side fender bottom
Passenger side bottom of fender:
Ford Maverick Front Bumper Panel Gap passenger side fender bottom
Driver side top of fender:
Ford Maverick Front Bumper Panel Gap driver side fender to
Passenger side top of fender:
Ford Maverick Front Bumper Panel Gap passenger side fender to
Driver side gap between headlight and fender:
Ford Maverick Front Bumper Panel Gap driver side fender headlight
Passenger side gap between headlight and fender:
Ford Maverick Front Bumper Panel Gap passenger side fender headlight
All of these things lead me to believe that the gap I am seeing between the bumper cover and passenger side fender is due to the passenger side fender being installed in such a way that the front edge of the fender where the headlight sits is angled up towards the sky very slightly, resulting in a difference in angle where the bumper cover edge meets the fender edge. It is not clear if this is because of the way the fender was installed at the factory or if it is because the stamping of the sheet metal is slightly off.
Could this be adjusted? From looking at how the fender attaches to the vehicle, it's possible that loosening the bolts would allow for some adjustment, but it is not something I want to do, and not something I want the dealership or a body shop to mess around with since I feel there's a likelihood that that could lead to more issues. In any case, I hope this is helpful if anyone else experiences the same issue.
Hoagus
Sacramento, CA
‘02 Ranger, ‘22 Mav XL
Uh oh… not I gotta go look at mine.
knightrider
Rick
Maverick XLT
My Ford dealer doesn't even to paint and body work anymore because of all the complaints. They farm it out to a Paint and Body shop ..
MavGeek
Western NY
2026 Ford Maverick XLT AWD Hybrid, 2024 Ford Edge ST-Line-AWD
Revived from the dead!
El Kabong
Carnation, WA
Ford Maverick Front Bumper Panel Gap muerto-dead-inside
