Four Minor Complaints with My 2024
Maverick Teacher
Boise
2024 XLT
1. the first door detent is too far away from the body. I've had to rest my door against the mirror on the car next door several times to get my things out since it hasn't reached the first detent yet. I will mention that this has always been on the passenger side since I walk over there to get my 2 bags out every morning in the work parking lot. Anybody else noticed this?
2. If you leave the radio on loud when you stop, it blares on at the same volume for several seconds until you can adjust it. The same thing happened on my Subaru.
3. TPS tire pressure sensor is way too sensitive. The first cold morning, it told me two of the tires were low. Of course, the day before with warmer weather, there was no indication. I filled them up and then again, a week later, on another cold morning, same warning again.
4.Too hard to change "sources" on the sound system. I plug in an old-school Ipod and it's a little bit of a pain to have the sytem find it. Once it does, it works great, however. I'm glad I insisted on the 2024 and not the 2025 so I still have actual radio buttons ha ha
Everything else has been working great-The AC and Heat crank! Also, towing the U-Haul trailer 1,000 miles up here was a breeze. No other issues so very happy so far with my purchase.
Deleted member 5352
Guest
A minor complaint I've had with mine is involving the A/C. I'll be driving on the highway for awhile with the fan speed on 1 and the temperature on LO. Then, all of a sudden, it feels like a ghost just turned up the fan speed without warning. I get these random blasts of higher speed air for several minutes until it goes away. Have you had that happen yet? Our Bronco Sport did that too.
alandcorbett
Alan
Holly Springs
MY23 Maverick Lariat
My truck also has the phantom come and turn up the air intensity. I feel it usually happens when I drive through a bend. It settles down if I change the output setting and the put it back to the original setting.
My A/C was insanely cold when I first got the truck. Now it is just barely acceptable. Brought it to the service department on a mild day and the technician told me I hadn’t turned on the A/C. Smh. My local Ford dealer generally has been terrible at taking care of my issues.
Bob zimmerman
Northern <MN
25’ Maverick XLT hybrid AWD
Seat belt status stays on for an hour!
Can’t keep my settings on the screen when I restart the vehicle!
Have to manually change to eco mode every single time I take it out of park or turn on vehicle.
icegradner
British Columbia, Canada
2022 XLT Maverick Hybrid
Seems to be something that happens to everyone, I guess it’s programmed to do that. Odd behaviour, but seems normal for this vehicle.
MYMAVXL
Chuck
Connecticut
Yup…I have the same problem. I usually just hit the window defrost button and let that run for a few minutes. I do lots of long highway driving and it gets pretty annoying. Lots of theories on this site, but so far no fixes. Does it in manual and auto modes…Brrrr!
KrS
KrS
St Marys ON
2024 Maverick XLT Tremor - Azure Grey Tri
I've honestly never had that happen unless i'm in an AUTO mode.
dbbii
Don
Tampa, FL
2023 Maverick
My daughter has a 2018 Explorer that does the same thing.
mirocada
Rhonda
OKC
2024 Maverick Hybrid
I also have the "hot ghost passenger" problem. Good, in a way, to know it's a common problem among different makes.
CrashedMaverick
Jack
Crashed Maverick
There is a great solution to that problem.
Mymavmode.com
Took me about 10 minutes to install.
Maverick Teacher
Maverick Teacher
Boise
2024 XLT
Oh yeah, I also had the "low washer fluid" light come on when it was practically full. I guess this is a known issue.
2024ash
Adam
Iowa
2024 Cactus Grey Maverick Lariat Hybrid
I'm three months in on my 2024. Biggest quibbles so far:
-Lack of radio presets. 12 total for AM, FM and Sirius is not enough.
-The radio has a mind of its own selecting an audio source upon vehicle start. It randomly selects AM, FM, Sirius, USB drive or Bluetooth. I can't figure it out.
-No 12v constant power. Why can't I charge a phone or other battery powered device while it's locked in the vehicle? 5000 mAh is not going to drain the 12v battery much less the traction battery.
-upon powering on the vehicle the engine randomly starts, even in circumstances where I believe the traction battery is well charged and am not demanding heat.
-Lariat trim should have some more information and options available on the EVIC. For example, coolant and transmission temperature.
-the amount of solenoids clicking and working while the vehicle is powered off for hours is both interesting and concerning.
I know this is a cheap vehicle, but these are all programming features and would cost next to nothing to implement when amortized over hundreds of thousands of vehicles.
