Forscan adjustment for larger tires?
BobsterD
Rio Rancho
2023 Ford Maverick Hybrid
Can anyone tell me if a adjustment needs made in Forscan when running larger tires? Going from 225's to 235's. Want to make sure the speedo remains accurate.
bgn
WA
It can easily be made to 235/65R17 since it is a factory option. I believe it's in the body control module tab.
Itsdavebr0
NY
2024 Maverick XL
225 to 235 is not a larger diameter tire. That is the tire width. Unless the tire aspect ratio is the same, but it wouldn’t change enough to necessitate changing anything with FORScan.
ScottyC
Central NY
2025 Ford Maverick AWD hybrid
According to Tire Rack looking at a Continental CrossContact LX25 tire (available in both 225-65R17 and 235-65R17 and used only to compare diameter as both are the same tire) the 225 clocks in at 28.5 inches overall diameter vs the 235 which checks in at 29 inches overall diameter.
Ford Maverick Forscan adjustment for larger tires? 1776261631188-6z
Ford Maverick Forscan adjustment for larger tires? 1776261705798-
Itsdavebr0
NY
2024 Maverick XL
Right, wider tire but the same aspect ratio means larger diameter. OP didn’t mention an aspect ratio. Could have been 235/60-17 which is a smaller overall diameter tire.
70mph on the speedo means 71.2mph actual speed.
I noticed my speedometer is off by more than that much with the same size tire as stock, just a different brand.
