cwedge
Nelson BC
25 Maverick Lariat
been trying the new Forscan release to disable the start stop feature. I havent been able to write the change to the module this is what i keep getting. any sugestion on what to do next anybody?
I’m getting same error as you.
Mabcim
Rochester, NY
I just used the test build 2.3.66, to make a back up of all the modules. It was not able to get into the IPMA module, but I could get into everything else just fine. I have sent a message to Forscan support. I'll update when I know more.
Jpalmer1
Dallas, TX
2025 Lariat Hybrid AWD
I would like to disable the external speaker noises for deer season. Anyone know if Forscan can do it?
Fehz
Midwest
2025 Maverick XLT
I can confirm that Forscan is working on the 2025s. I backed up all of the factory settings. I did switch the EQ to flat, the audio was really bad after the change. I will measure the output before and after when I have time. I used the same address as the Bronco.
EQ Setting, 01 is On, 00 should be Flat or Off.
ACM 727-01-02, XX01-XXXX-XXXX to XX00-XXXX-XXXX
Just did this and it worked great for me using a kicker lx 1200.5 with a kisload4 in front. Seems the built in DSP likes the flat signal much better.
I also found a newer test version of forscan available - same link as before but a date of 20250406 in the file name.
Ryom
PA
2025 Lariat 4K BAP Eruption Green
I'm interested in turning off the seatbelt minder with Forscan. I'm getting a message that isn't showing in the tutorial vid however. Should I proceed through this screen?
Ford Maverick FORScan 2.3.65 Released. Supports 2025 Maverick Screenshot 2025-04-15 170048
Mabcim
Rochester, NY
I haven’t seen that screen before. If I read it correctly, you have DTC code in that module. You can go to the DTC tab and clear it there. The only thing is that it clears all DTCs, no way to clear just one. You should read up on the DTC to see if it matters or not. Sometimes playing with Forscan will throw a DTC as it resets. If I see one that has a timestamp that matches with me doing Forscan stuff, I figure it isn’t a problem. If you can’t, then it might be something you want the dealer to look into.
Mabcim
Rochester, NY
I tried this version and I still cannot get into the IPMA module.
I had no luck with Forscan support has I‘m still using a free license. I know, the cost is low, just haven’t done it yet.
M7153DRC
Dustin
MT
2025 Maverick
Does anyone know if it's possible to remove the seat belt reminder message from the instrument cluster but keep the chime reminder with Forscan? So far I've only been able to remove both.
