Flat tow a AWD with it in neutral and the engine idling?
Motorjunkie
Hermitage, Pa.
73 vette, 71Fiat 850, 91 Mercedes 500SL, 2001 F150
Well there is a setting for the hybrid to be flat towed easily set by the drive mode button below the shift knob - the steps are ( and also in the owners manual ) -
  1. Do not exceed 70 mph
  2. Put the vehicle in "neutral tow" mode; follow these procedures found in the owner's manual
  3. If you're towing the vehicle a long distance, run the engine for one minute at the start of each day (or every 6 hours)
So no the motor "doesnt have to be running" - only every 6 hours or start of day. But again it just takes a minute or two to read the owners manual to know that indeed it is safe to flat tow it and not post " Great way to ruin a brand new vehicle and NOT have warranty fix it." which on the hybrid is 100% NOT true and I would add it IS designed for that since there is actually a setting for doing just that. But your original question was actually WHO would want to flat tow a Maverick not the procedure TO do that. The answer is again , usually RV folks with a big motorhome.
Charlie Daubitz
Charlie Daubitz
Charlie
St petersburg fl
2022 Maverick 2.0 AWD 18" rims Cactus Blue
4WD vehicles used to have in - out hubs, someone could make some for the Maverick!
BDennis
Bruce
So Cal
My hybrid with a Roadmaster baseplate
Ford Maverick Flat tow a AWD with it in neutral and the engine idling? D77BCE31-F44A-4E87-96D7-DD57DFDD55E9
Me B
home
2022 Maverick, 2006 Fusion, 2001 Ranger, Ford F53
I thought it was a good question because I would like to tow my AWD behind my motorhome. I just went and tried. It's either 30 minutes nuetral by pressing L while in N or it goes to Park when you open the door.
  • Like
Reactions: bgn
KeithVi
Keith
Toyota Camry SE
If you remote start the hybrid while in tow mode will the e-cvt remain in tow mode?
LSchicago
Lloyd
IL
Could you flat tow a AWD with it in neutral and the engine idling?
You bought the wrong truck. Only the hybrid can be flat towed. Buy a trailer, or trade for a hybrid.
LSchicago
Lloyd
IL
BDennis
Bruce
So Cal
Starting the engine requires you go into the truck to disengage tow mode. At least every 6 hours you have to start the engine, with your foot on the brake shift into drive for 30 seconds, shift into reverse for 30 seconds then turn the engine off and renegade tow mode.
