First oil change 2025 hybrid
SlickSpace
N
socalet
2025 maverick
My 2025 XLT hybrid fwd just clocked little over 1 k miles. I decided to get new oil n filter in. I was surprised that the oil from factory is like greenish color? and the oil filter was smaller than the one I pick up from the dealer? Have anyone else experience this before?
Ford Maverick First oil change 2025 hybrid IMG_6858
Ford Maverick First oil change 2025 hybrid IMG_6857
Mxer97
R
H town
2023 mav xlt
Yes, and yes.
The Real Maverick
Jack
Really though, that green oil is special for break in. Some say it helps for 5000 miles. Other do as you did and change it at 1k for unknown reasons.
And you are about to become castrated for not reading existing posts on this topic. Just FYI.
SlickSpace
SlickSpace
N
socalet
2025 maverick
my bad!
Toddman45
St. Louis, MO
I'm more surprised you're changed the oil with only a thousand miles on it, unless the trucks already a year old.
710-oil-614
Cal
2025 Hybrid AWD Lariat
Because engines break in and wear and it’s best to get the break in oil out sooner than later. I’m more surprised you didn’t know this and do it yourself.
The Real Maverick
Jack
Some say it's green for easier leak detection.
Some say it's green due to special ingredients.
Some say change it early because "probably" there's metal shavings in there.
But no one lab tests that stock oil (sadly I didn't either since first two were free at the dealership and I didn't tell them "hey save me half a pint") so the world may never know!
heady
MI
'25 Lariat
Longer drain intervals and older engine oil reduce engine friction and wear due in large part to ZDDP deposition on surfaces. Each oil change "washes" these antiwear film deposits off, leading to a spike in surface scarring and wear metals immediately after each and every oil change. https://www.sae.org/publications/technical-papers/content/2007-01-4133/ - iirc you can get the full paper on scihub.
NYbiomed
Rick
New York
2025 Lariat
Did my 1st change at 28xx miles, I kinda felt that waiting a bit longer for the "break-in oil" to do it's job was appropriate, then get it out...definitely didn't feel 7500 mile inotial OCI was a good idea. I'm going to have them performed every 6k moving forward. We have to consider that the hybrids will cover about 10-20% in EV mode, reducing any wear during those miles covered...but I'm definitely NOT going to sweat if I'm 500miles over/late too.
