So basically i bring the 2 power cables to the front bumper harness and ground i used the same.ground of the sidemarker bulbs. But with the wire harness i make for ppl i put a cable for ground with a eyelid for 10 mm next to the conector theres a hole you can install it there. I put a picture so you can see.Im very close to doing this, if the weather just warms up a bit more.
I have a quick question.
If the BCM sends power to each fog light with those 2 wires you pinned to it and ran through the firewall....where did you get the grounds for each light?
just in case ppl need this informationhi guys im making a wire diagram to try to simplify the job for you guys can you guys give me an idea so i can make it easier for you guys to install it yourself i will take any advice thanks . heres something im in the procces of making. heres an example of pin install on the youtube link.
The wires i will try putting labels on them and the pins will have blue and red shrink tubing so you know wich one its left and right.
Perfect, thanks!!So basically i bring the 2 power cables to the front bumper harness and ground i used the same.ground of the sidemarker bulbs. But with the wire harness i make for ppl i put a cable for ground with a eyelid for 10 mm next to the conector theres a hole you can install it there. I put a picture so you can see.
Does anyone know how to program the cluster with a 6.5" screen via FORScan to show the fog light indicator? I checked the IPC and couldn't find the "Fog Lamps Available" option. I have a 22 Hybrid Lariat.I installed the F-150 Powerboost light switch and now have a working fog light setup on my hybrid.
The switch is a fairly straightforward swap out and in. The wiring side was also pretty simple although WT-1004 turned out to not be the right size. I suspect it's one size smaller (WT-1003?) which I happened to have from saving some other Ford connectors, but I'll be able to measure and confirm when I get back in to work tomorrow.
FORScan settings are mostly self-explanatory. Enter 'Fog' into the search field on the BCM and that will show all of the relevant ones. I did have to set my 'Front Fog Lamp Usage' to 'Fog Light' instead; 'Power Supply' just seemed to have them on all the time initially. You can also set if you want them to stay on alongside High Beams. I also had to go into the IPC (instrument cluster) settings and set 'Fog Lamps Available' to 'Enable' for the dash indicator to work.
Can you send me a picture of your options on the ipc screen ?Does anyone know how to program the cluster with a 6.5" screen via FORScan to show the fog light indicator? I checked the IPC and couldn't find the "Fog Lamps Available" option. I have a 22 Hybrid Lariat.
nevermind lol the "Fog Lamps Available" was one of a few options that is written in a different language on my forscan lol Everything works now! ThanksCan you send me a picture of your options on the ipc screen ?
How was it listed? Asking because I plan to add fog lights and also have the larger screen instrument cluster.nevermind lol the "Fog Lamps Available" was one of a few options that is written in a different language on my forscan lol Everything works now! Thanks
If your forscan is in English, you should be able to search for the keyword "fog" in the IPC module.How was it listed? Asking because I plan to add fog lights and also have the larger screen instrument cluster.
Will you be able to help me with wiring or can you make me one.If anyone have any question or would like me to make the wiring for you let me know i will gladly help.
I can make you one or assist you doesn't matter to me. If i make you one im going to need to know what kind of lights your using .Will you be able to help me with wiring or can you make me one.
I have an XL hybrid and planning on to get the diode dynamics foglamp kit.I can make you one or assist you doesn't matter to me. If i make you one im going to need to know what kind of lights your using .
In that case you only need one wire from Bcm to the diode dynamics wire harness and your done and change the settings on forscan to enable the foglights and fog lights switchI have an XL hybrid and planning on to get the diode dynamics foglamp kit.
Has anyone looked into this setup to see if the DD setup just uses a big relay? I would like to do the same DD with factory switch but prefer to eliminate as much potential failure as possible and go from the BCM direct to the lights if it would work.In that case you only need one wire from Bcm to the diode dynamics wire harness and your done and change the settings on forscan to enable the foglights and fog lights switch
Yes this ^^Has anyone looked into this setup to see if the DD setup just uses a big relay? I would like to do the same DD with factory switch but prefer to eliminate as much potential failure as possible and go from the BCM direct to the lights if it would work.
