Automan21
Mel
‘23 XLT Eco AWD 4K Tow
No, because you shouldn't do anything with the wiring at the switch itself. The only four wires there are: Ground, Power, Cargo (Gr/Vt), and LIN [Local Interconnect Network] (Blu/Gy) with the lattermost the digital communication line to the BCM that actual changes in the lighting are transmitted over.
Great, thanks for explaining that!!
So just waiting for ups to deliver my replacement today.
Dmat
Baton Rouge
MAVERICK
Ok i got my set of fog lights from Diode Dynamics and got their wire harness with me and wiring diagram. I have been sick for the past 3 days with covid or flu but unable to touch my truck or think straight stucked on bed.
Heres a picture of the option if you want to use their harness and my bcm terminals to fog lights kit. If you prefer their harness then what i would do its wire up everything like they say. With the power with fuse and relay and ground to battery what ever. But the difference its where it says Switch Input install just 1 pin from the bcm to there and you should be able to use the f150 fog light switch.
Or wait for me to get better health wise and post a how to when i get a chance this week.
Thanks for giving a proper answer to my guesses. I'm sorta shooting in the dark to figure stuff out without spending money until I get everything figured out.
What is the program you're using to see how to take apart the truck?
710-oil-614
Cal
2025 Hybrid AWD Lariat
Hope you're feeling better man!
I like options! But I still like your first run at it with your created harness.
If you did this simple switch wiring with the Diode Dynamics harness - would the OEM functionality (when enabled via Forscan) still work? Dash emblems, working with auto-headlights, etc?
FischAutoTechGarten
Peter
Well, a 2nd place took my order for ML3Z-11654-BC on Thursday, but cancelled it today... Bummer.
However, found 1 that was in stock (their last one) and ordered... actually cheaper overall than the other orders. So, hopefull I'll get this quickly... DD Elite light kit has already arrived... (well ahead of the March estimate... woohoo)
Vtec87pr1
Vtec87pr1
Antonio
Virginia
youtube.com
2022 XL Ford Maverick
Yes. Even they will turn off when you turn high beams on. Like oem .
Vtec87pr1
Vtec87pr1
Antonio
Virginia
youtube.com
I think im not using the elite fog lights and just using my way. And my own fog lights and just using the brackets they provided. Heres why im looking to make it look like the truck came with them. The elite its fine and the back lights looks good but not for me. Im happy they made the brackets and they look very clean built . Great job from diode dynamics. And i also happy that im able to use my own ford oem f150 fog lights on the brackets. For either halogen bulb or led fog lights from ford.
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY 20240129_181730
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY 20240129_181843
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY 20240129_181935
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY 20240129_181939
710-oil-614
Cal
The Tremor tow hooks are what restricts me and ties me to the SSC1s (or Morimoto XB Bangers) - basically a 2" pod unfortunately
VicRattlehead
Mokena
Couple ford cars and a truck
Got this message from Varsity Ford this afternoon when I tried to order this switch
As of 1-29 FORD has part ML3Z-11654-DC on a National Back order with No Release date & No Notes. All FORD Depots are out of stock at this time
FischAutoTechGarten
Peter
True, but it's the ML3Z-11654-BC that us EcoBoost folks want.. We dont' have a locking gas cap door. But alas, I can see that's it's a problem for Hybrid folks..
that said...I had a ML3Z-11654-BC order cancelled twice as well... So let's call national backorder on both parts...
Dmat
Baton Rouge
MAVERICK
I know your bypassing the harness from DD. Can you say whether you think the fog light switch could be changed to something different? Seeing your pictures, It seems like it would be possible to add a more narrow switch to the right side of the current lamp control.
A switch about 0.7-0.75 inch wide (maybe even 0.8", but that'd be pushing it) could fit to the right of the dimmer buttons, yes.
Automan21
Mel
If anyone have any question or would like me to make the wiring for you let me know i will gladly help.
Im very close to doing this, if the weather just warms up a bit more.
I have a quick question.
If the BCM sends power to each fog light with those 2 wires you pinned to it and ran through the firewall....where did you get the grounds for each light?
peekaypee
Paul
San Diego, CA
Toyota Pickup, Maverick Lariat Hybrid & Tremor
Hi again VTec, I'm sorry, but I'm not sure what your name is. I'm Paul. Thanks for your instructions earlier and hard work and hope you're feeling better. I think a lot of us are getting some bug this year, maybe more so then before. I was checking back to see if you were able to come up with some kind of wiring harness and specialized instructions to work with DD's, fog light kit? I've never used forscan, but I think I can learn from all the great input here on this forum. I would like to purchase the DD fog light kit and then get that F-150 light switch with the hybrid gas door button and fog light control button and hook it up correctly so it would be working like factory. So I was just coming back around to see where you're at and if you wanted to make a kit and sell it to me with instructions. That would be great 😃
