Nexoidian
Aaron
2022 Explorer, 2018 WRX
I posted this in the escape cluster thread, but figured it probably deserves its own thread because it is not an escape swap.
I finally got a chance to install my explorer platinum 12” cluster. I started off with an escape 12” cluster that I got cheap locally. It worked great and was only 600 miles more than my odometer at the time. So I waited until I was over the escape’s mileage and then installed it in my 2024 Maverick XLT FX4. I was able to increase the mileage on the escape cluster to match my current odometer. I didn’t realize at first that I would lose tow/haul mode and snow/sand mode. I struggled to get the drive modes to work on my truck. I followed all of the recommendations in this post with forscan and spen at least another hour trying different settings. I could select a drive mode and it would work as long as the truck wasn’t started. Once I started the truck I couldn’t change the drive mode. Not even go back to normal.
So with that issue and losing the 2 modes I decided to find an explorer cluster. It was harder to find a deal on the explorer one, but got a decent deal on eBay. Unfortunately they didn’t list mileage on the listing, so I didn’t know what I was getting. When I received it I found that the mileage was about 30,000 more than my current odometer. I messaged Dave with @Clusters by Livnitup. I had Dave do 2 previous clusters for me in the past for my F-150s. He said he wasn’t sure if he could correct the explorer mileage, but would give it a shot. Luckily he was able to adjust the mileage to match my predicted odometer reading when I would receive it back.
Last night I removed the escape cluster and tried to install the explorer cluster. I kind of had a feeling based on other people’s experience the explorer cluster wouldn’t mount with out some modifications. The main issue with the explorer cluster is the clear lens housing for some reason is a little bigger than the escape/maverick cluster. I figured it was worth a shot to swap the lens from the escape cluster to the explorer cluster. That worked with a little trimming of the plastic tabs where the bottoms bolts mount to the dash. I also had to make the aluminum tabs for the bottom bolts a little smaller. The explorer cluster has 2 bolt holes in the bottom tabs and the escape/ maverick only have one bolt hole. I used a cut off wheel on a dremel to trim the aluminum tabs. After cleaning the cluster and lens really good to remove the debris from the cutoff wheel I test fit it. Luckily with the slight modifications it fit just as it should.
Once installed I tested the drive modes and all of the drives modes were there as they would be on a stock maverick cluster. I also test starting the truck and selecting and going thru the drive modes. Everything worked as it should.
So for anyone curious the explorer cluster will work with all drive modes. Down side is the slight modifications. I preferred not to modify the truck and that’s why I modified the cluster.
I'm attaching some photos, I wish I would’ve taken more pics. But you can see in some of them how the bottom tabs are different between the two vehicles. The pictures of the cluster removed show the explorer Lens on the escape
My only real gripe is that the normal mode doesn’t have the tach on the right side like the escape cluster does. Different modes have it on the right. But not normal or eco mode. I’m wondering if a firmware update would change that. But I doubt I’ll ever be able to get the firmware updated.
Ford Maverick Explorer 12” digital instrument cluster installed in my 2024 Maverick IMG_5791
Ford Maverick Explorer 12” digital instrument cluster installed in my 2024 Maverick IMG_5799
Ford Maverick Explorer 12” digital instrument cluster installed in my 2024 Maverick IMG_5798
Ford Maverick Explorer 12” digital instrument cluster installed in my 2024 Maverick IMG_5789
Ford Maverick Explorer 12” digital instrument cluster installed in my 2024 Maverick IMG_5800
Ford Maverick Explorer 12” digital instrument cluster installed in my 2024 Maverick IMG_5813
Ford Maverick Explorer 12” digital instrument cluster installed in my 2024 Maverick IMG_5814
Ford Maverick Explorer 12” digital instrument cluster installed in my 2024 Maverick IMG_5810
Ford Maverick Explorer 12” digital instrument cluster installed in my 2024 Maverick IMG_5809
TonyJoe
Antony
Broomfield, CO
1998 Ranger XLT 4.0
Wow, that looks so nice. Definitely something Ford should offer as an option when building. My biggest gripe about the Maverick cluster is not being able to display any other stats digitally when using the speedometer. I like the analog power gauge but the analog speedometer is quite useless.
Bwicka
Lakeside,ca.
Awesome , love these upgrades and experiments , we all need to keep it up.
groovesocket
Atom
Central TX
2022 Cyber Orange Ford Maverick XLT Hybrid
Please elaborate on "...the analog speedometer is quite useless." My analog speedometer works fine. It does what it's tasked to do. It's pretty accurate in letting me know the speed my Maverick is traveling at.
22Lariat
New Hampshire
2022 Ford Maverick Lariat
That's pretty cool. I like it.
I have the lariat lux with the FX4. I like that cluster too. I think you had the same cluster I have. I'm curious why you didn't like it. Did you just want all digital 12 inch?
Cool swap though.
Mav2
Dee
Detroit Michigan
All Fords
Great Job that's awesome!!
Montana
So normal mode is just blank on the right side? lol why? Is it like this in the Explorers too? Strange.
Iakona
Jason
Elgin, North Dakota
2023 Maverick Tremor
If you don't mind me asking, How much dis the digital Explorer cluster run you? I managed to get an all digital Escape one for $300. I may look into the Explorer cluster since I have a Tremor and wouldn't lose as much functionality with one of those. I haven't installed the Escape cluster I have done in waiting for my truck mileage to catch up to the new cluster mileage. Lol. 17k on the truck versus 19k on the cluster.
Nexoidian
Nexoidian
Aaron
I ended up paying $300 for the explorer cluster on eBay. The escape cluster I feel like I got a steal on for $75.
There were quite a few explorer clusters on car-part.com when I was looking.
Iakona
Jason
Elgin, North Dakota
Not bad. I may see if I can find one and sell the Escape one. Could I have the part number please. Thank you.
commadorebob
What gets me is how the odometer data is within the cluster. Seems like an easy way for fraud if not for Ford Pass.
Nexoidian
Nexoidian
Aaron
Nexoidian
Nexoidian
Aaron
My explorer cluster is:
LB5T-10849-GJ
