Exhaust will need serious help.
Mav
E
Earth
Lariat Maverick
Dual 3” exhaust on an inline 4 cylinder. What?
My comment too. Waste of space, material, weight, and money. A single is a much better choice.
ColoradoShooter
Colorado
Tacoma/Fusion
A 2.25/2.5” single is more than enough. The real issue is the integrated “exhaust manifold” cast into the cylinder head. Terrible airflow design.
Mav
E
Earth
Lariat Maverick
Yup. Restrictive cast manifold will definitely kill flow. I’m sure there are ton of aftermarket options for the 2.0eb. 2.25” pipe would be fine with the stock turbo. I’d probably going a little bigger though.
SPRMAV
Phoenix
Now sounds like a deep throaty Focus RS. Shaved off 26lbs
Ford Maverick Exhaust will need serious help. 927DB543-674E-4054-A706-22CC1FE3954F
Ford Maverick Exhaust will need serious help. 4F85110D-7976-4626-8FD8-3C85D1204395
Ford Maverick Exhaust will need serious help. 7CC0E635-476C-4F77-B1AE-1AC8E5395D2F
mamboman777
Josh
NRH, TX
OP photo is a testing mule, not a production truck. Almost all of Ford's testing mules have cobbled together exhaust systems that look like Zeke made them down on the farm with a hammer and pliers.
Ford Maverick Exhaust will need serious help. Almost Politically Correct Redneck 03112021041538
Dueces
How do you tuck that anymore than SPRMAV did? Looks pretty tucked to me.
Buschur
Wakeman, Ohio
2020 F150
I posted a video, the exhaust will help a lot on this platform. It's one of our next projects as soon as we can get the truck on the lift. We've done a catch can and intake for it already.
We won't offer duals, it's a waste of time, money, labor and material, no flow improvements going from a single to a dual, typically actually hurts. We will concentrate on keeping as much ground clearance as we can, sound and increasing power.
vezpa
vezpa
EMG
IL/IN border
Too many to list.
When you remote start your truck in the cold and walk up to it from behind it seeing 2 trails it instantly becomes worth it.
Ronbye
Ron
Newfoundland
2019 Subaru Crosstrek
Is the exhaust system on the hybrid stainless steel?
Mabcim
Rochester, NY
The Escape 2.0 has dual outlets. It is a single pipe to large rear muffler/resonator, then 2 outlets from it.
I suspect the Bronco Sport Badlands is the same.
I’m pretty sure that is the setup on my Fusion 2.0 as well.
So yeah, not true duals, but looks like it out the back.
Would like on the Mav as well, but the spare tire is kind of in the way. However, SPRMAV found a way around it. 👍
felsf50
Scott
NEPA
It will be a little more of a challenge to "fix" the stock exhaust on my Maverick. I just saw this undercarriage shot.
Dear god is this the worst looking exhaust setup I've ever seen on a truck. Going for 3 inch stainless duals tucked up high. Why does this setup hang so low? WTF? :sick:
Ford Maverick Exhaust will need serious help. PXL_20220103_202749909.MP~2
Ford Maverick Exhaust will need serious help. PXL_20220103_233707368.MP~2
Ford Maverick Exhaust will need serious help. PXL_20220103_233658133.MP~2
Ford Maverick Exhaust will need serious help. PXL_20220103_203901123~2
