Engine temperature up and down
Fx4hOok
Kevin
MA
Maverick 2.0 FX4
Fx4 Eco: Engine temperature gauge keeps going from 4 to 3 sticks and vice versa every minute or so while driving, anyone also has this issue ?
Mavman123
Joe Shmo
Hybrid Maverick XLT
How's your coolant level?
Decayed
yes
a car
This. First thing I'd check. Second thing I'd do is call the dealer. Could be a bad temperature sensor or a bad thermostat.
Has it been doing this for a long time or did it just start? Do you have an OBD scanner? They can usually read the temp sensor data in real time.
Fx4hOok
Fx4hOok
Kevin
MA
Maverick 2.0 FX4
Been doing since i got it, i dont know if the cold weather could be the issue, has been below 32 everyday but my 15 camry gauge never moves dont matter what.
Decayed
yes
a car
It also might be that the normal engine temp just naturally straddles the point between the bars on the gauge. But I'd call the dealer.
The Weatherman
Dean
KY
No, I have not seen that on my 2.0 Eco FX4 LARIAT.
Fx4hOok
Fx4hOok
Kevin
MA
Maverick 2.0 FX4
Thats what it looks like, i just bought and odm at wal mart and went for a drive.
When there are 3 sticks temperature is 177.80 or below, 4 sticks 179.60, and temperature bounces between 177.80 to 179.60 t0 181.40 while driving, stays steady at 181.40 at idle, now the questions is, whats the engine
normal operating temperature suppose to be at ?
So the temperature bounces between 81, 82, 83 Celsius.
Does anyone have an odm and can check their temperature please ?
Decayed
yes
a car
Huh, didn't really expect that. 4 degrees variation isn't a lot and 181 seems like a reasonable idling coolant temp.
What's the outside temp in your area? Colder than usual?
Does the odb reader show the temp rise normally from ambient? You would start at ambient, the it would rise until the thermostat opens at which point it would drop some, then rise some and level off.
I checked the owners manual but couldn't find anything about the normal temp. What kind of ODB reader did you get? A stand alone or the kind that links with a phone app?
Fx4hOok
Fx4hOok
Kevin
MA
Maverick 2.0 FX4
Stand alone, it is 17F outside.
Ford Maverick Engine temperature up and down 20220130_173407
tomahawk72
Travis
Westbrook, Maine
22 Maverick XLT
I think the thing we have to remember too is that the Fx4 package has a bigger radiator which helps with cooling. In colder climates like here in Maine it means we might see a bit more temperature variation depending on how the engine is running. Mine does the 3-4 bars thing as well but I have had no issues so far.
Fx4hOok
Fx4hOok
Kevin
MA
Maverick 2.0 FX4
Thanks, so i am not the only one then, it is 17 outside, i wonder if this would happen when is 90 outside.
Decayed
yes
a car
Makes sense.
FX4dude - Call the dealer and ask if they know what the operating temp should be and how much to expect it to vary. If you're in the ballpark then you know not to worry.
Recently my wife's car decided to run at a slightly higher temp as visible on the dash. The coolant looked a bit low so I topped it off. Since then it keeps running a bit higher but we've had it on long trips with no problems and the coolant level stays stable. I think it was a stuck temperature gauge.
dalola
Retired
SE Ohio 🇺🇸
Most OEM thermostats are in the 190-195 range for emissions. What you're seeing seems normal for extreme cold weather and low load driving.
