Ecoboost- Powertrain Malfunction/Reduced Power - Four-Wheel fault
Nw_adventure
Salt Lake city
Driving 80 heading to Southern Utah, got the error message tool wrench on the dash and then power was cut- Not super awesome but luckily I was close to an exit, pulled off to turn off the engine and let it sit for a bit.
Turned back on without an error and finished the rest of the 4 hour drive without incident- Vehicle did not overheat- Anyone else had this random message and what could be done to avoid this in the future ? Going to see if my dealer can get more info on the specific error.
billbillw
Metro Atlanta
'23 Maverick Lariat FX4
Probably nothing you did to cause it, meaning nothing you can do to avoid it. Probably a random error in the immensely complex engine/drive train monitoring system, or something is marginal and will probably happen again and require a repair. Your dealer should be able to pull a stored code.
Ford Motor Company
Official Ford Account
Dearborn, mi
mrstaylor3711
Utah
2023 Ford Maverick XLT
Coincidentally enough this occurred to me last week on 80 just outside of Elko.
Service engine soon light came on followed immediately by Powertrain Malfunction/Reduced Power.
The engine governed itself down, we pulled over and turned it off. Waited 10 minutes and it started back up without the warning and continued on.
Called our service department and they convinced me to swing through Gallagher Ford in Elko so they could have a look. They were kind enough to stop what they were doin and troubleshoot. 3.5hrs later they determined it was the wastegate solenoid but they didn’t have one in stock to replace it.
We made it back to Utah and brought to our local service department. They tried replicating the code over the weekend but it didn’t happen.
They wont replace the waste gate solenoid now because they claim Ford wants to see the code twice before they’ll fix it. Basically they said I needo be stranded on the side of the road again before they can do anything.
Is this really the way they operate?
Or do I need to pushback?
**The code originally popped up toward the end of a 6 day 2200 mile road trip.
Montana
Yep I've had it as well on both my previous Escape and the current Maverick. Apparently and update fixed it on the Maverick but they had to replace an entire module on the Escape. Like you said, it's a miscommunication at start up and can be managed by just restarting. I found it happened more often in cold climates on cold starts. I have also started, rolled forward a bit then back, shut off and restart to solve it too. FORD's service here will likely just confirm your VIN and ask you a bunch of info like your name and address so they can put it in their system and track you then refer you to your local dealer once they have that info. It's a TSB so your services dept. should be able to schedule you for the fix. It's really nothing to worry about but should be addressed when you can get scheduled.
Nw_adventure
Nw_adventure
Salt Lake city
Does this reduced power error only happen in the Mountain/West ? LOL - Will check in with the local Ford Shop foreman and see if he has heard anything about this error and or finicky solenoids -
chuck k
chuck
2022 ford maverick fx4 2.0 awd
Yes, I currently have my 2022 fx4, xlt 2.0 l turbo at the dealer now with a similar happening on I90 south, travelling 65mph and dropping to 20mph without warning. Not for the faint of heart. The only thing I can think of is ,I had just had the taillight recall performed and I had the start/stop switch deactivated. I have 11747 miles and love the truck, but 65mph to 20mph on I90 is an unforgiveable sin. The ball is in Fords court.
Nw_adventure
Nw_adventure
Salt Lake city
In my situation I was able to exit without dying - Went right to the gas station parking lot, turned the truck off. Waited a couple minutes, restarted and the truck was fine. It's been almost a year since that episode and it's not returned thankfully.
Nw_adventure
Nw_adventure
Salt Lake city
**UPDATE** My Powertrain malfunction/Reduced power/Fault has returned with a vengeance after almost a year of being dormant- Now its also brought along a buddy- Low/Turbo/Boost fault - At the dealer and still no word on a remedy-
Anyone got the TSB # and or more info on this "software update* ? Thx-
Nw_adventure
Nw_adventure
Salt Lake city
- Being told the defective Turbo/By-Pass Valve is actually the culprit of the low boost warning but also the powertrain malfunction/Reduced power/Fault - Hoping this is the case and just replacing the valve solves the terrifying forced power reduction -
Tom 71 Maverick 24
Northeast Ohio
It's dangerous if you're driving on the freeway with the flow of traffic. And it's dangerous if you get stranded in a bad part of town.
Nw_adventure
Nw_adventure
Salt Lake city
All of the above. I was doing 80 (Utah Speed Limit) and was instantly dropped to 55 - Unreal level of BS -
Montana
Yea it's just dangerous period. Not something you want to see in a new(er) vehicle either.
IamthNight
Erik
2022 For Maverick Hybrid
Hi There, was the issue resolved? I just got the powertrain error message yesterday. Went away after I turned the car off.
