E85 on a 2.0L Maverick
MavOrMan
Drake
Kansas City
Doing the RS intercooler and CAI this weekend, and also installed a catch can, wanting to also go E85. Does the HPFP off the RS work on the maverick? Is there a better route? Is there anyone already running straight E85?
Dueces
I'm running out of fuel on E30, but I am running a Corsair turbo. I think some guys are running E50, but haven't really heard of anyone running full E85. I haven't looked into the RS 4 lobe pump, I had heard that was a common upgrade for the FoST peeps.
COBB Tuning
Diamond Sponsor
Austin, TX
2022 Ford Maverick Lariat
The HPFP doesn't seem to be the limitation - it'll hold 3600psi without issue running as much boost as the stock turbo can happily make with E50. At that point, the limitation is injection window/injector sizing. HPFP drive lobes are not a part of the pump, but are a feature of the camshaft that drives the pump, and the Maverick already has four drive lobes per cam rotation just like the RS. Compared to the Maverick, the Focus RS pump may actually decrease fueling capacity. I'd be curious to see whether Nostrum/XDI/FIC injectors for Focus ST/RS applications would fit...
Dueces
I haven't monitored fuel pressure on my setup to see if it's tapering off. I purchased a larger low pressure pump to see if increased flow will help me max out the corsair turbo. Another issue though, is the 2.5bar map sensor, because I'm at that limit as well....
SDNative
Daniel
San Diego
XLT
The JB4 tuner marketing info claims plug and play tunes for e85. Anyone on here have experience with running e85 on just a tune?
GPSMan
Many
I have experience with E85 but not in this vehicle.
Romac
Roman
Louisville, KY
Sorry I‘m Late to the party, is the RS intercooler a direct replacement/improvement?
I’ve been curious about a lot of the parts commonalities.
mykream
Massillon, OH
2002 Corvette Z06, 2022 Maverick
Glad to see you guys on it.
Vtec87pr1
Antonio
Virginia
youtube.com
2022 XL Ford Maverick
me trying to leave my engine alone just in case needs a head gasket or long block since its traditions soon and i see all this mods.... man so temping
Snox801
Levi
Spring Lake Michigan
Just an update. Mine is going in for e85. Hpfp is fine but it needs injectors.
Livernois has a few e85 ones done. I’m booked for second week April
Shoptruck
Dirtcoast
23 maverick xlt awd 4k fx4, 22 maverick xl awd 4k
Update??
Snox801
Levi
Well I only did the standard tune. The maverick did so well hauling that I’ve been using it more for work which is what I got it for.
Second reason is my wife got rear ended and have no date for the ranger raptor we had on order. So this may have to fill that gap for a min.
sweetbete
Peter
Los Angeles
2023 Maverick 2.0 Lariat, 2009 Mazdaspeed3
I can't find any data on ethanol blends on our ecoboosts so I have some results to contribute using Los Angeles 91 Octane Costco Gas (E10) mixed with E85 (G&M Oil).
2023 Maverick 2.0L FX4 4k-Tow Lariat
Stock injectors
Stock HPFP
Stock ECU (no tune)
Below are WOT pulls on the FWY (3rd - 4th gear to see data during shifts as well) for E26 - E48 (E15 and E20 runs were before I installed Flex Fuel sensor so I am not posting these). Full tank per ethanol blend. ~2,000 mile experiment.
E26 (26.4%)
Ford Maverick E85 on a 2.0L Maverick 1782444411342-p4
