DTC Questions
Stizzed
Michael
Northern Indiana, USA
2022 Ford Maverick Lariat
After purchasing my used 22 Lariat Hybrid with 35k miles on it a few months ago I've recently seen the wrench light a few times so I hooked up forscan and pulled the DTCs.
For the experts (and curious here) here is what Ive found. A few questions first:
1) It does not seem so but are any of these serious enough that it needs to see the mechanic immediately?
2) How likely is it that any of these would be covered under the remaining warranty?
3) Is it common to see this number/frequency of DTCs with these modern electronic 'chines?
Note that I also have a few Drivetrain Alerts in the Ford App but I cannot tell what they are. I assume that they are related to these errors.
Thanks in advance!
===PAM DTC U0415:00-28===
Code: U0415 - Invalid Data Received From Anti-Lock Brake System (ABS) Control Module
Status (-28):
- Previously Set DTC - Not Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Module: Parking Aid Module
===END PAM DTC U0415:00-28===
===GSM DTC P0929:77-2C===
Code: P0929 - Gear Shift Lock Solenoid/Actuator Control Circuit 'A' Range/Performance
Additional Fault Symptom (77):
- Commanded Position Not Reachable
Status (-2C):
- DTC Maturing - Intermittent at Time of Request
Module: Gear Shift Module
===END GSM DTC P0929:77-2C===
===SCCM DTC B135C:13-28===
Code: B135C - Heater Element
Additional Fault Symptom (13):
- Circuit Open
Status (-28):
Module: Steering Column Control Module
Freeze Frame #1:
-MODULE_VOLTAGE: 12.5 V - Control Module Voltage
-IGN_STS_SCCM: OFF - Ignition Status
-ELE_PWR_STS_SCCM: error - Electric Power Status
-PWR_TQ_STS_SCCM: Powerpack Off Torque NA - Powerpack Torque Status
-EVENT_TIME: 110435829 s (Fri Mar 21 20:17:10 2025) - Event time
===END SCCM DTC B135C:13-28===
===IPMA DTC C1001:97-68===
Code: C1001 - Vision System Camera
Additional Fault Symptom (97):
- Component Or System Operation Obstructed Or Blocked
Status (-68):
- Test not complete
Module: Image Processing Module A
Freeze Frame #1:
-EVENT_TIME: 109227963 s (Fri Mar 07 19:46:04 2025) - Event time
-TOTAL_DISTANCE: 35241 miles - Total Distance
-MODULE_VOLTAGE: 15.0 V - Control Module Voltage
-OUTDOOR_TEMPERATURE: 31 °F - Outside temperature
-VEHICLE_SPEED: 43 mph - Vehicle Speed
-ECU_POWER_SUPPLY: 14.7 V - ECU Power Supply Voltage
-ECU_INTERNAL_TEMPERATURE: 91 °F - ECU Internal Temperature
===END IPMA DTC C1001:97-68===
kbuchle2
Lariat Hybrid
Thanks in advance!
Status (-28):
Status (-2C):
- Circuit Open
Status (-28):
Freeze Frame #1:
Status (-68):
- Test not complete
Freeze Frame #1:
I don’t have a solution for you on the DTCs you are mentioning here, but I also have “
Status (-28):
Module: Parking Aid Module” present in my logs on my vehicle. Scheduled a dealer appointment to have them look at it tomorrow since my bumper to bumper warranty is up on 03/28. Will post back on what they tell me.
inline_five
2023 Hybrid XLT
I believe the "not present at this time" note means it's no longer a factor.
I disconnected my 12v and the BCM set a fault that I later pulled but was "not present at this time".
Forscan found it, my regular OBD2 did not, probably because it wasn't active.
If under warranty I would have them check it out but if not, clear it out and see if it returns after a week or two of driving.
kbuchle2
Lariat Hybrid
Thanks for the insight on that. I’m new to forscan as of about a week ago, so still learning some of the terms.
For me at least, I’ve cleared this code a few times, very next drive cycle it returns. So it’s triggering at first startup maybe? Not sure, would keep clearing and testing but with the bumper 2 bumper running out on Friday, figured I’d better be safe than sorry.
inline_five
2023 Hybrid XLT
Istartup maybe? Not sure, would keep clearing and testing but with the bumper 2 bumper running out on Friday, figured I’d better be safe than sorry.
If it's returning there is an issue. Definitely take it in.
I'm new to Forscan too. So far I really like it. Might be the reason I stick to Ford in general in the future with ability to do factory tests and programming from home without additional costs.
710-oil-614
Cal
2025 Hybrid AWD Lariat
Seems like an issue, have you scheduled a service appointment? What have they said?
kbuchle2
Lariat Hybrid
I’m a software engineer by trade so it’s been fun to get this kind of data and tinker with things. I did the fog light mod with the F150 hybrid light switch and used Forscan to control the fog lights through the BCM. Love the functionality and then started digging into the world of DTCs.
  • Like
Reactions: bgn
kbuchle2
Lariat Hybrid
Appointment scheduled for tomorrow morning, hope they have an answer later in the afternoon. I would’ve kept testing over a week or so but was thinking along the lines of what you were saying - need to take it in before my warranty expires, which is this Friday. Luckily my dealer was able to squeeze me in tomorrow after I noted that my factory warranty was expiring soon.
kbuchle2
Lariat Hybrid
So update on this one, took my truck in this morning, tech mentioned that they had to perform “a bunch of software updates” and that I should be good to go now.
Not sure @Stizzed if you still have any factory warranty left but I’d take it in and ask them to check for any SSMs. It looks like we both have the same truck (down to the color!) so chances are that “ ===PAM DTC U0415:00-28===
Code: U0415 - Invalid Data Received From Anti-Lock Brake System (ABS) Control Module” should be fixed by the updates that they will run for you.
On a related note, I had another DTC for a low battery (can’t remember the actual code) and mentioned it to my service advisor and they replaced my 12V today. In the 3 years I’ve had my maverick this is the 3rd battery it’s had.
colinl
Colin
ICT
if you see the wrench light on again definitely park and leave it in the on position and then look with forscan before you turn off the ignition.
