Just got my 23 Lariat hybrid back from a week‘s stay at the dealer to cure POC48. A problem was found with the High Voltage Coolant Pump. Pump was replaced. Anyone else experienced this DTC?
P0C48 (#0 not letter O) is the DTC.Just got my 23 Lariat hybrid back from a week‘s stay at the dealer to cure POC48. A problem was found with the High Voltage Coolant Pump. Pump was replaced. Anyone else experienced this DTC?
Thanks, Kevin. I will update with any further issues.P0C48 (#0 not letter O) is the DTC.
This DTC sets when the feedback signal the BECM receives from the high voltage battery coolant pump indicates the control circuit is open or shorted to ground.
Possible Causes
- Wiring, terminals or connectors
- Low coolant level
- Air in the cooling system
- High voltage battery coolant pump
- BCMC
- BECM
I can't recall seeing anyone else having a problem w/ this code.
