First issue with my MAV DTC P2D01
Vongreg
Greg
Arkansas
Hybrid Camry, chevy 2500 HD, Maverick Hybrid
Pulling out on the highway lost power. Just enough to do a u-turn back onto the county road. No check engine light. Turned it off and restarted and all was fine. Decided to cont the trip. Made it a couple of miles and the check engine light came on. Decided to head home and check the codes. Lost power a couple of times during the trip home. Got a high temp battery warning when I pulled into the drive way. I checked the codes and the only code showing was P2D01 Motor electronics coolant pump over speed/Air in the system.
There is a TSB out on 2020 hybrids on the issue. it says to reprogram the BCEM. This is mainly for Hybrid Explorers, Aviators and Interceptors. Found a TSB for the Escape also.
I will load it up on the trailer tomorrow and take it to the local Ford Dealer Monday. We will see what happens.
Vongreg
Vongreg
Greg
Arkansas
Well that’s a kick in the pants two local dealers, one said Friday at 3pm and the other doesn’t answer the phone. I figure it will be a month or two before I get to drive it again.
glider
So Cal
2002 4runner 2019 Honda civic
That's a drag. Let us know what happens
Samola72
Samuel
Baltimore
Ford Mavericks 2022
Good evening,please kindly help me with information regarding the P2D01 code on how the problem was resolved, my maverick is giving me the same code with the same symptom, please help me, thanks.
Ford Motor Company
Official Ford Account
Dearborn, mi
Hi there! Will you send us a message with your VIN and your local Ford dealer? I can look into things on my end.
MM Mav
Amy
Great Lakes Region
@Ford Motor Company @Samola72 OP posted this thread 4/9/22 and hasn't visited the forum since 4/25/23. They're likely not going to respond to you.
