drive axle failure
rpost
Rodney
VillaRica GA
2023 Maverick hybrid
2022 maverick with front end vibration and harmonic - diagnosed with drive axle failure at 68000 miles-whats up with that?
my left is sour for the 2nd time , they are Hyundai made and the CV’s are to small for the application
Jroberts302s
Josh
Nashville, Tn
2023 maverick,2012,fusion, 2014 focus,2003 cobra
ugh we had to have both of them replaced @ 60K
Darryl
Darryl
Tallahassee Florida
2025 Maverick XLT HYBRID
You only have a recall if life safety is involved. That’s why so many car manufacturers have chronic defects but are not covered by the manufacturer after the warranty expires.
If a failure rate is high enough and outcry is loud enough, SOMETIMES Ford will issue a voluntary good will field service action which will in effect extend the warranty on the part that commonly fails early. Example: they extended the warranty on their ill rated dual clutch automatic in the focus and fiesta to 10 years 100, 000 ( or so) instead of the usual 5/60 power train warranty. I'm not sure the failure rate on the axles is frequent enough or the outcry high enough for that. But it could be possible. As it stands the axles are covered under 5/60 powertrain warranty. So if yours is going to fail, hopefully it will fail before then. And you will likely get the updated part number that's less failure prone.
