Does mounting a dash cam behind the rear view mirror affect the Ford cameras?
NJBob
New Jersey
I am getting a dash cam and was wondering if anyone had an issues mounting them close to the cameras. Or should I make an effort to get it as far away from the ceras as I can.
paneubert
Seattle
I think the manual says it is a bad idea (maybe that was the manual for my wife's 2024 Subaru, can't recall specifically), but in practice it is fine. The front facing camera is encased behind a plastic shroud and is looking forward, not directly below itself. Stuff on the glass below that shroud should not have any impact since it is outside the view of the camera. Think about it.....if the front facing camera could see your dash cam mounted below it, that means the front facing camera angle would be pointed down at your hood, etc...
NJBob
NJBob
New Jersey
Thanks, I think I may have gotten that thought from the wife's Subie also. Thanks
Toddman45
St. Louis, MO
I have both my dash cams mounted behind my rear view mirror in both of my 2019 Explorer and 2024 Maverick. No issues
Ford Maverick Does mounting a dash cam behind the rear view mirror affect the Ford cameras? PXL_20240906_053424789
Ford Maverick Does mounting a dash cam behind the rear view mirror affect the Ford cameras? 20240913_155423
Ford Maverick Does mounting a dash cam behind the rear view mirror affect the Ford cameras? 17343064238625242366462339154912
icegradner
British Columbia, Canada
2022 XLT Maverick Hybrid
No issue with a dash cam mounted in the same area other people here are showing, had one there since day one of owning the truck over 2 years ago. Only time I get error warnings about the camera is when the window gets fogged up at the top.
NJBob
NJBob
New Jersey
Very nice. Hooe to find one under the tree.
Vafordman
Virginia
2024 Maverick xlt Tremor
Which camera did you purchase? I'm going to be getting one, I want a rear facing one too
Toddman45
St. Louis, MO
I have the Cobra SC250R. The front is 4k and the rear is 1080p. I hard wired them.
Ford Maverick Does mounting a dash cam behind the rear view mirror affect the Ford cameras? PXL_20240906_053221704
Toddman45
St. Louis, MO
Here's a photo of the box for you if you care. I always keep the boxes to everything I buy at least for a couple years.
It also came with a 32 GB micro SD card. There's also an expansion port for a in cab camera if you care for that. So this supports three total cameras at the same time.
The front is 4K and the other two are 1080p.
Ford Maverick Does mounting a dash cam behind the rear view mirror affect the Ford cameras? 17343893755103995036051435488308
Ford Maverick Does mounting a dash cam behind the rear view mirror affect the Ford cameras? 17343893904651768512471042572292
Vafordman
Virginia
Thanks it's appreciate that
