Whatthewhat11
Zach
Pittsburgh
I use the USB slots in my vehicles often but I don't like the clutter of a bunch of balled up cords under the dash. I didn't want to hard wire anything and I didn't want to occupy any existing power source either. I decided to go with this cigarette lighter adapter. (https://amzn.to/3GgIK4X).
First I ran the cable under the climate controls. There is a small space between the center console and the lower dash where you can thread the cable neatly behind the dash (Pic 1 & 2).
Ford Maverick DIY Center Console USB Power Strip 20221220_162717
Ford Maverick DIY Center Console USB Power Strip 20221220_162743
Next I removed the center console panel which is secured by a few clips. I secured the wire to the steel support beam located just behind the climate controls with a zip-tie to stop it from sagging under the dash (Pic 3).
Ford Maverick DIY Center Console USB Power Strip 20221220_162754
Next I drilled a hole in the center console to feed the wire through and installed a rubber grommet for a more finished look (Pic 4 & 5). This was awkward and requires a right angle drill attachment and a short drill bit to be able to drill in the correct orientation. I had to cut the wire, feed it through the hole, and then crimp it back together. Getting the wire up through into the center console was a little cumbersome, so I removed the passenger seat to allow for some more room to work. It could absolutely be done with it in though. Either way, you will have to remove 4 bolts on the center console (2 driver side, 2 on passenger side) in order to lift it enough to get your hand under the console to feed the wire through.
Ford Maverick DIY Center Console USB Power Strip 20221220_221206
Ford Maverick DIY Center Console USB Power Strip 20221220_221217
Lastly, I trimmed the carpet piece to fit around the power strip and used some 3M double sided tape to secure it to the bottom of the console (Pic 6). Overall I am very happy with the install. I can now charge all my electronics out of sight and I still have 2 USB slots at the 12V site well.
Ford Maverick DIY Center Console USB Power Strip 20221221_005435
Clarkdonbran
Make it with Mav!
MiMav
'23 EB FX4 4k Maverick, '14 Escape
I like it. I may do the same thing if/when I get my Mav.
The Weatherman
Dean
KY
Good idea. Nice Job. Nice Writeup. And thanks for sharing. 😊
Fordmn
Roger
Ohio/Florida
Maverick XLT Lariat
Next I removed the center console panels which are secured by a few clips (Pic 3). I secured the wire to the steel support beam locatrd just behind the climate controls with a zip-tie to stop it from sagging under the dash (Pic 3).
Next I drilled a hole in the center console to feed the wire through and installed a rubber grommet for a more finished look (Pic 4 & 5). This was awkward and requires a right angle drill attachment and a short drill bit to be able to drill in the correct orientation. I had to cut the wire, feed it through the hole, and then crimp it back together. Getting the wire up through into the center console was a little cumbersome, so I removed the passenger seat to allow for some more room to work. It could absolutely be done with it in though. You will have to remove 4 bolts on the center console (2 driver side, 2 on passenger side) in order to lift it enough to get your hand under the console to feed the wire through.
Lastly, I trimmed the carpet piece to fit around the power strip and used some 3M double sided tape to secure it to the bottom of the console (Pic 6). Overall I am very happy with the install. I can now charge all my electronics out of sight and I still have 2 USB slots at the 12V sias well.
Fordmn
Roger
Ohio/Florida
Maverick XLT Lariat
GREAT... thanks for sharing, and great job of telling what you did, how u did, and with pictures....
Got my Xmas gift this morning from Ford...Email my Mav was built on 22nd and should be at my dealership by end of January.
Just over 3 months from ordering Lariat completely loaded , Hot Pepper Red.
My first car was 1972 Maverick, wish I still had it!!
Planning my flight north to get it and drive back to Sunny Florida...
RanCheeto
Volt, Audi TT, 59 Corvette, 30 Model A, etc...
I like the idea, thanks! I'll probably grab the connection from the back of the center console though.
Hardening2753
Ford Maverick Hybrid
Looks awesome 😎
Phileaux
Frank
New Orleans, La
2010 Ford Edge SEL fwd
Great idea and execution. One concern is the open USB ports facing up. Eventually something besides a plug is going to block it.
Pickles
Calvin
Kia rio, kia sorento
Nicely done! Sadly my center console is a wasteland of receipts, napkins, and random objects so this isnt ideal for my electronics haha bit its a nice idea and some more organized people will love this
BlueRaven
Iowa
24 Mav, 01 CRV
i double side taped mine to the bottom of the console by the usb plugs. having plugs inside the console is silly to me.
Whatthewhat11
Zach
Pittsburgh
I charge multiple electronics and it clutters up the bin under the climate controls. Many vehicles come with a USB in the center console.
