Kris Kelley
Kris
Jackson, TN
2023 Ford Maverick
I’ve been trying to come up with a solution when I’m running to the grocery store and I have 2 kiddos with me. This divider with 4 hooks on one side and chest latches securing a 2 x 4 x 54 3/8” to a 2 x 8 x 54 3/8” (tapered down a 1/4” at the bottom) will keep things from sliding around! I used a textured black paint and also cut grab handles in the 2 x 8 using a 2” hole saw and a jig saw. Total cost was $46 and took about an hour of time without counting paint dry time. This also includes 4 additional hooks that I haven't (not sure that they are needed) attached yet. I am going to grab another chest latch tomorrow to add to the center of the other side to snug it together a little better. It will also make the unit a more solid, finished piece when attached.
Ford Maverick DIY Bed Divider with Grocery Hooks IMG_0958
Ford Maverick DIY Bed Divider with Grocery Hooks IMG_0960
Ford Maverick DIY Bed Divider with Grocery Hooks IMG_0961
Ford Maverick DIY Bed Divider with Grocery Hooks IMG_0962
Rmengel
Rick
Hartland MI
2023 Maverick Lariat
Do you know the measurement from side to side, also how high to be even with the top of the wheel well ?
Kris Kelley
Kris Kelley
Kris
Jackson, TN
2023 Ford Maverick
I haven’t measured to the top of the wheel well, but side to side is 54 3/8”. I tapered the bottom by 1/4” to make it “lock” into place a little snugger.
lewiskauffman
Lewis
Chambersburg PA
2022 Ford Maverick XL
Cool! I did a similar thing but added a center divider. Also put a single cross piece at the front of the bed (near the cab) to have support front to back for carrying 4 x 8 sheets of plywood.
Edit: I have the drop liner for the bottom only. The 2 x 8 was ripped to be 6 1/2" wide to match the wheel wells- for my truck. Same for the "front" cross member.
Ford Maverick DIY Bed Divider with Grocery Hooks IMG_1522
Kris Kelley
Kris Kelley
Kris
Jackson, TN
2023 Ford Maverick
Cool! I did a similar thing but added a center divider. Also put a single crosse piece at the front of the bed (near the cab) to have support front to back for carrying 4 x 8 sheets of plywood
That's a great idea. I had not thought about it doubling as a support structure. The reason for adding the handles was to pull it out easier if I needed to load something larger. I will check to see if the 2 x 8 (7 1/4" actual height) is the same as the wheel wells. If so, then just unlatching the 2 x 4 and removing it will make a great support structure to carry plywood etc. Another thing I thought about, and will probably change this week, is using eyelets instead of open hooks and attaching carabiners to them to secure bags.
Jone
Jonathan
Mi
2024 Mav
Thanks! Someday I will have something very similar but I need to come up with a way to cradle a two wheel dolly as well.
I think I better get the truck before I build the divider though…
Hot Runr Guy
West Chicago, IL
I went with this support design for 4x sheet goods. FYI, the ends are NOT 45 degree cuts,,,,
HRG
Ford Maverick DIY Bed Divider with Grocery Hooks Maverick load support
MoeMav
Moe
Baker, FL
2024 XLT
Same here! I have so many things on my “Mav accessories” list that I want to get going on, and my bride keeps reminding me to wait until I actually get the truck. Dang it!
Dmthomp32
Doug
Charlotte
2023 Ford Maverick
I’ve got a 2X6 across my rear of the bed. The measurements the OP provided are accurate, just need to shave down the corners of each end for a nice snug fit that will also come out! I never thought about putting handle holes in mine. That’s a great idea. I considered other options to keep objects in place/stop them from moving. But honestly I bought some ford rubber mats from Ollie’s, cut and fit them for $20. Even with the drop in bed liner underneath the rubber mat, nothing moves.
Luthinator
24' Mav. Lariat Hybrid & 23' Ford Explorer XLT+
I'm right there with ya! One day... Maybe February.
Kris Kelley
Kris Kelley
Kris
Jackson, TN
2023 Ford Maverick
Can you send a pic of the mats from Ollie’s? Curious about how that turned out.
710-oil-614
Cal
2025 Hybrid AWD Lariat
Hooks look great! I made a divider from 2x8 that drops in (no fancy handles) but it was too heavy for me to want to keep back there all the time.
Ended up getting a ratcheting bar from HF that I put about 6" off the floor of the bed but bags still slide side to side.
Good work!
rclee
Rob
Dayton Ohio
I built one out of a 2x6 and it is a pain in the butt to get in and out. Handles are a good idea and rounding the bottom corners sounds like a good idea too. BTW you can use the "Bottle Opener" Tie downs at the top rear to hang the grocery bags on. I also used some cheap door stops on the top of my 2x6 to hang them from.
Ford Maverick DIY Bed Divider with Grocery Hooks IMG_0806 (1)
Dmthomp32
Doug
Charlotte
2023 Ford Maverick
So these FoMoCo rubber mats were sold through Ollie’s at some point this summer. I heard about them through this forum. My Ollie’s didn’t put them out until about two months after others had purchased their mats. I don’t recall the exact price but I want to say they were $10-$15 a piece.
I assume they were for another vehicle but with some minor trimming they fit pretty well. One May gets you most of the bed covered. I bought two and trimmer them to fit, and the seem is right beneath my 2X6.
Ford Maverick DIY Bed Divider with Grocery Hooks 0FE8BB0D-9B9C-40D8-BE38-9595D989997C
Ford Maverick DIY Bed Divider with Grocery Hooks E3A801D5-91EE-4257-9D92-8429F949B5E0
Ford Maverick DIY Bed Divider with Grocery Hooks 7284D48E-1E88-4A54-8CF7-1016C8BA4681
I have A tonneau cover but even when it’s rolled up they haven’t moved on the highway. It’s a fairly heavy duty mat. For me it was cheaper than buying a maverick specific mat. Doesn’t look terrible (YMMV), but more importantly it works great!
