Dim Infotainment Screen.... Possible Fix?
Sykotyk
Ohio
Just experienced this today and want to relay it to others to try.
If you're like me the screen is very dim during the day to the point that Google maps is barely usable in satellite mode.
I check my setting and it's as bright as possible.
But today I did something different. I turned down the brightness all the way and.... There was no change. But when I turned it back up the screen got bright!
It's so much brighter now than it was. Not sure what the cause was or if it's just a fluke with mine. But I've noticed mine seemed to keep being dimmer and dimmer over time but was always set the highest. Try it. See if it works for you.
Wizard
Russell
Kentucky
2023 cactus grey Maverick XLT
Thanks, I'm going to try that cause mine seems dark to me .
TRUCKHEF
SOCAL
22' Ford Maverick XLT
50% to 100% brightness is the same. don’t forget cluster brightness switch next to left knee also controls brightness.
huunvubu
coppell tx
2023 Ford Maverick Hybrid
Did not work for me.
I did the "turned down the brightness " which did no dimming until below the 50% mark then the display got dimmer until the "all the way down" mark.
Then I did the "turned it back up". The screen did brighten until it reached 50% when it stopped getting any brighter and the brightness was exactly the same as before even with the setting at 100%.
Sykotyk
Ohio
Did not work for me :( from 50-100% no brightness change.
That sucks. Yeah, mine didn't darken at all from 100% to 0%, and then got bright all the way up through the bar.
Ford Motor Company
Official Ford Account
Dearborn, mi
Hey! I can take a closer look into your dimming screen concerns if you would like. Can you send us a direct message with your VIN and the dealership name/location?
TRUCKHEF
SOCAL
There isn’t anything that can be done, it’s just the way it is.
FunctionSpec
San Gabriel Valley, CA
2022 Maverick HYBRID XLT LuxPkg
You can try connecting the Infotainment System to WiFi and turn on Automatic Updates. My screen used to be dim but once I connected the system to wifi, it one day just fixed itself. No idea if it did an automatic update but screen is not dim anymore.
Sykotyk
Ohio
Well, bad news on my end. Got in the Maverick today and again the screen looked really dim. Did this again, it did it again. But now the sun was out bright, and made the screen mid-day really tough to see. The fact it's aimed toward the center console AND downward, makes it already troublesome to see. The dim screen just makes it worse.
So, either it's resetting it darker every time, or I just did it on a cloudy day and didn't really do much to increase overall brightness.
I'll try that today.
yamahaSHO
Jason
Greenwood, AR
22 Ranger, 07 Sky RL, 04 S2000, 07 Jeep CRD
The screen on my wife's XLT is nearly worthless in the day. I lose focus on the road just trying to see it at times.
Ford Maverick Dim Infotainment Screen.... Possible Fix? 1000004378
I contrast to my Ranger, which is way better.
Ford Maverick Dim Infotainment Screen.... Possible Fix? 1000004416
Is the Sync 3 screen brighter? If so, I'd swap one in.
billbillw
Metro Atlanta
'23 Maverick Lariat FX4
There are multiple settings for the screen brightness. Make sure the instrument dimmer is set on the higher side as well as the settings in the menu. From the look in that photo, the instruments are very dim, which may be the problem. That is the setting above your left knee. The instrument brightness setting with the headlights off is different from when it senses darkeness and turns on the headlights.
Occasionally I see it glitch and it is too dim, but most of the time my non-sync 3 screen is more than bright enough for any amount of day brightness.
billbillw
Metro Atlanta
Everything is full bright. Let's assume I am a little smarter.
Those cluster lights are not at full brightness. If the adjustment is full, then there is something wrong. Headlights in Auto mode? Not "On"? Take it to the dealer to sort out if nothing else suggested above helps. The instruments and the screen should be much brighter.
