Detailing question.
LOBOtime
Detroit, MI
2025 Maverick Lobo
What is the best way you guys have found to remove debris from the space between the cab and the tonneau cover? Aside from removing the cover all together.
Ford Maverick Detailing question. IMG_6357
Shop-Vac first to get the large real loose stuff out then change and use a crevice tool I then change the hose and put it to the exit air side of the back and try and blow out whatever I can and use a long bristled paint brush.
I also have the option of using an air compressor.
Ah the disadvantage of a unibody "truck".
nandesho
Houston, TX
‘23 Hybrid Lariat BAP, '24 Hybrid XL
I use one of the sticks I find in this area to dislodge other debris while blasting it with a handheld leaf blower.
I'm considering putting some low density foam in this crevice, but I fear that could become a mold/insect magnet.
Grabbs
Virginia
Maverick Lariat
I put weather strip in between. No crap falling in now.
ripperAZ
AZ
2022 Mustang MachE 2021 Genesis G90 2032 Mav
crevice tools, air gun tweezers, skewers from your grill anything that can get the large chunks out blow from the cab back and most of it come shooting out if you have a good air gun I actually use my lawn blower the first time
DWV
Don
charlotte nc
2024 Maverick
Just be sure to use closed cell foam, not open cell-which acts like a sponge.
Rigel7
San Marcos,TX
Ford maverick
I jammed some foam weather stripping in the gap, works pretty good.
MaverickMark
2023 Maverick Lariat
Mine has no gap. I don't have that problem. I have the hard roll up from the Ford store.
Ford Maverick Detailing question. 20250726_153603
Cancunbadlands
Cancun
Cancun
Shop vac
Ben2023L
Ben
Nashville, TN
2023 Ford Maverick 2.0L
I put a piece of weather stripping/ modeling there - seems to work well. You can’t even notice it’s there, blends right in
dochawk
doc
Las Vegas
80v blower:
Ford Maverick Detailing question. 1761617943961-27
:crackup:
they really are the same power as a 50cc gas (I didn't believe the claimbefore I started buying them, but yes, they are).
Or, I have an air gun for my compressor, which is basically a trigger on a quarter inch copper tube. I have it to restart cooling coals in my smoker.
