Daylight savings woes with clock
MLowe05
GA
Should be once you set daylight savings ON
Unless I’m misunderstanding the toggle, you have to toggle it on or off manually to adjust the clock. It won’t automatically do it.
Hilltop
Leigh
Vista, CA
2022 Ford Maverick XLT hybrid
Update. This morning the correct time was still there so I guess it eventually decided the new time was ok. Weird but not a big deal in the scheme of things. I’m still enjoying this truck.
TedTX
Ted
San Antonio TX
Sorry, put in the wrong time… too much detail. That has a very high probability based on experience to fix the underlying issue.
Mitchell Lorens
Mitch
West Sacramento, Ca.
Maverick Lariat hybrid
I was hoping my truck would automatically update the clock to “fall back” but alas, no. So I proceeded to manually go in to the settings and adjust it manually. However, the next time I started the truck, instead of the correct time, the clock showed “— —“ so I manually entered the correct time again. This scenario has now repeated three times. Is anyone else experiencing this? Any suggestions?
I changed time yesterday but haven’t driven it since. Now I need to go out to my Mav and check the time, fingers crossed!
1buddyc
Buddy
San Antonio, Texas
2021 Lincoln Nautilus 2025 Eruption Green Maverick 2006 Chevy SSR
Had to manually adjust my clock, no problems, it reset just fine.
jsus
2022 Ford Escape Hybrid AWD
That’s cause you have to toggle on “change automatically”
Please provide instructions to do that on Sync 3, as I’ve never had that option, whether on 3.0 or the newer 3.4.
“Reset clock to GPS time” did push it to update, while stating that it doesn’t factor in DST. Really, that means that it switches to standard time for your time zone regardless of DST, since the satellite doesn’t know if your specific location has DST.
