Dash center speaker rattle - update (good news - bad news)
campngolf
Back 40
Cmax
So my truck has developed a rattle (clunk) that sounds like it's coming from under the dash very near the center speaker. I'm wondering if anyone has removed the speaker cover for the center dash speaker. It appears to just snap in place but wanted to check first before I go all Hulk on it.
The noise sounds like it might be a wiring harness connector clunking around.
UPDATE - So yes, the center speaker cover is easy to remove. It has six clips that popped off with a trim tool and a bit of persuasion. But, removing the cover did not give any real access to the under dash area like I had hoped.
Now I need to decide what will be plan B. Either removing the screen or attempting to crawl up under the steering column to see if I can locate the source.
clos0791
Carlos
Maverick Lariat, Alto Blue AWD
Mine seems to come and go with outside temperature. When its warm/hot, I don't hear a rattle. I live in SoCal so it is warm most of the year. These rattles can drive you nuts for sure. I will keep searching for a solution.
I agree with you. It sounds like a loose wiring harness under the dash that is hitting something. It is such an easy fix I am sure once you are able to isolate it/find it.
RJC
RUSS
NL CANADA
2022 FORD MAVERICK CARBO GREY AWD XLT
Had the dash rattle in the MAV as well, just recently had the side curtain airbag recall done and rattle has disappeared, they had all the upper panels off and dropped the headliner to do the recall . Hopefully this issue is resolved!
bgn
WA
The noise is likely not a loose wiring harness. It's likely the windshield alignment pucks at the top hitting the metal. Had the same issue. Windshield was resealed, but some folks just melted them down. There are threads on that in the forum if you search more.
Aherpa
Iowa
Edge, Maverick Lariat Hybrid
With the cover off, did the noise go away?
campngolf
campngolf
Back 40
Cmax
Nope. It actually sounds like it's coming from down in the vent in front of the speaker. Kinda like something fell down there during the build. I'm not giving up on finding it just yet.
Aherpa
Iowa
I have found other rattles by having someone else drive over the same road that made the rattle in the first place while I hunted around for them. I'm always annoyed that a noise sounds like it's coming from there only to find that it's located somewhere else.
Good luck
FlyGuy09
2023 Mavrick
Any updates to this? Just bought a 2023 Lariat, and I badly have the center dash rattle up around the center speaker cover area. In fact if I bang my fist on too of the dash in the center it rattles too, but not on either side if I hit it.
campngolf
campngolf
Back 40
Cmax
No update. I haven't looked into the issue since posting. I think I might take the speaker cover off again and see if I can remove the speaker to see if that gives me any access to the area in question.
FlyGuy09
2023 Mavrick
Cool, keep me posted! I was thinking of doing the same. But i’ve only had the truck for 4 days, so it’s the last thing I feel like doing.
Pharmboy
Justin
Lariat
I have a 2023 Lariat Hybrid and my dash rattles have gotten so bad I'm embarrassed to have someone ride in my new vehicle. It is mostly coming from the right side of the dash and right door area but also have some small rattles coming from both defrost vents. I have an appt with my dealer this week. Hope they can resolve it.
Zotman
Detroit suburbs
Lariat Lux Hybrid, Focus
Likely won't help many, but I resolved MY Lariat rattle thusly: the huge black plastic monstrosity attached to the upper middle of the windshield (which is seemingly designed to obstruct one's view and to which the rear view mirror is attached) snaps together. While prowling around while the wife shopped I noticed the bottom right corner was loose and a firm but gentle push seated it with a 'click' and we no longer hear the rattle. Good luck to all, but Federal Law requires the disclaimer YMMV.
FlyGuy09
2023 Mavrick
Nice find! Yea mines definitely coming from the dash though.
