Cut key and fob,save 100's,$$
GADM
Guy
Missouri
2025 Ford Maverick XLT
Yup, need the two keys to DIY. AI is incorrect (shocker!)
@Vegasbaby - my son-in-law got a used 2020 Explorer from the dealer with one key. I wouldn't buy a car with one, I'd make them create a new one so I'd have two, especially from a Ford dealer. I got spare fobs for my SIL and now he has to spend big bucks to get the second key so I can make spares.
Did "Vegasbaby" by his Maverick from a dealership?
I certainly wouldn't walk away from a truck I wanted because it only came with one key. Especially one as hot as a Maverick.
To me, it would be a point of negotiation. Not an ultimatum.
Vegasbaby
Orlando, FL
Unfortunately not a Ford Dealer.
Are those guys in the Home Depot parking lots with a van and a tent a viable alternative to the actual dealer? I’ve seen them a few times.
Fibrepunk
2023 Ford Maverick XLT Hybrid
Yes. Costco also has the "Key" van in the parking lot/tent from time to time and they can cut/program the FOB for you.
Vegasbaby
Orlando, FL
Didn’t mean to hijack this thread.
I’m going in for my first Oil Change next week at 4400 miles 😵💫 (4% oil life left?) and was thinking I need a spare (drop) key. Was reading on here and this one was fresh so thought I’d chime in.
Bear
Oakland County, MI
Ford Taurus & Maverick XLT Hybrid
No, they can't program the Maverick key fob, I asked them already. I lost a key fob too and I' have to go to the dealership to get a replacement. On my current key fob I placed an Apple AirTag on my key ring so I can locate it.
(nice to see the OLM doing it's job on EB also - lots of towing or idling?) Not a hijack!
No fobs are programmed.
The vehicle is programmed to accept the transponder code in the fob.
If you had 2 good keys, and they could cut the key correctly - you could have programmed the truck yourself.
But ya for the price they probably charge - they won't have the scanner and skill to do the vehicle side if just 1 good fob.
Look for a coupon for a locksmith, or auto shop with means to program truck - maybe you'll get lucky and cheaper than dealership.
kevinmccune
kevin
BATH CO ,VA
2022 XL maverick
most greedy Ford dealers have lost my interest,my next Ford(if ever) would probably be "long macarthur" the local legal stealership have screwed me enough already.( they are not even local 50 plus miles away)
Mike,
If you only have one original key/FOB left and a locksmith or Ford has to reprogram the truck for the new key/Fob.
Will the Original key/FOB still fully function with the truck?
Mike,
Yes - they get into the system and from the videos I've seen showing it done in Forscan - they clear out all the keys (since one is lost at this point), and add the 2 valid ones.
And why I'd feel uncomfortable doing it in Forscan.
That's when my adapter would select to lose connection and require a key cycle to reconnect.
Except no valid key...
brlr2000
Bruce
2024 Maverick XLT Hybrid
Lone Star Proud
William
Central Texas
Ford Maverick XLT
I purchased one of these 12/24 for my 23 Maverick XL. Differnt vendor but same description (Maverik). Received it and it programmed fine. Used it for my main key for a while (maybe a month). It looks identical, although the plastic and button feel is cheaper feeling than OEM FOB. Then one time I went to take the key out it seemed "stuck" in the ignition. Odd since it worked perfectly until then. I carefully giggled the steering wheel and key and eventually got it out. Since then I used it as a hide a key. I've tried it since and it's worked fine. Probably just a burr on the key from cutting. No regrets buying, just be careful. Maybe rub with an emery cloth and spray with a lubricant before inserting the first time.
I use mine as a third key I have hidden it in the truck. It has always worked for me when needed. It's a comfort to know it's there and it saved a lot of money.
Bobby Chapman
Bobby Chapman
Bobby
Orlando fla.
2023 maverick
They are at Costco's also
