Extra key and fob
Joew_ski
FL
2024 Maverick Lariat Hybrid
Keyslot - no.
Starting a Hybrid Electric Vehicle System - Vehicles With: Push Button Start
Before starting your vehicle, check the following:
  • Make sure the parking brake is on.
  • Make sure the transmission is in park (P).
Note: Do not touch the accelerator pedal.
  1. Fully press the brake pedal.
Ford Maverick Extra key and fob {filename}
  1. Press the push button ignition switch.
When you start your vehicle, a green indicator appears in the instrument cluster letting you know that your vehicle is ready for driving. Since your vehicle is equipped with a silent key start, the engine may not start when your vehicle starts.
When the engine starts for the first time on your drive, the idle speed increases, this helps warm up the engine. If the engine idle speed does not decrease, have your vehicle checked by an authorized dealer.
The system does not function if:
  • The passive key frequencies are jammed.
  • The key battery has no charge.
Starting and Stopping the Engine – Frequently Asked Questions - Vehicles With: Push Button Start
Why is the engine not cranking?
The engine does not crank if:
  • The system does not detect a valid passive key.
  • The passive key battery has no charge.
  • The vehicle battery does not have sufficient charge.
  • The brake pedal is not pressed for automatic transmissions or the clutch pedal is not pressed for manual transmissions.
  • The transmission is not in the park (P) or neutral (N) for automatic transmissions.
  • The starting system has been disabled after multiple attempts of starting the engine.
What should I do if the starting system is disabled?
  • You can only attempt to start the engine for a set number of times before the starting system temporarily disables. If you exceed the limit, a message may appear and you need to wait at least 15 minutes to start the engine again.
What happens if the system does not detect a valid passive key?
  • If the system does not detect a valid passive key, the engine does not start and a warning message displays in the instrument cluster display. To start the engine insert the passive key into the backup position and press the push button ignition switch to start the engine. See Accessing the Passive Key Backup Position .
The last manual search is for you - so you can get to know it!
There's your fishing pole.
dochawk
doc
Las Vegas
How / where is emergency key placed/used to
did you post this isn every single vaguely related thread?
The mildest term I can come up with is "obnoxious".
How / where is emergency key placed/used to manually START 2024 Mav Lariat FWD Hybrid when FOB portion is not working or is lost?
Is there a hidden emergency key slot somewhere?
Nope
With push to start. Even though you have an emergency key allowing you to unlock and enter your vehicle,
without the fob present, you cannot start the vehicle. The battery in the fob can be low at which point you put the fob on the designated space inside the console. Allowing you to start the vehicle.
If you have the emergency key but have lost the fob your S.O.L., until you can retrieve your second fob, call Ford for a tow or locksmith.
