djwinter
Doug
bay Area
2022 XL
XL owner. I have been looking at various after market and oem tie down solutions. Some d-rings and the pre-threaded holes in the bed worked great. Highly recommend it. I went with 4 on each side, maybe overkill. But $20 versus hundreds for a rail system.
Ford Maverick Cheap and Easy Tie Down Solution IMG_7397
Ford Maverick Cheap and Easy Tie Down Solution IMG_7396
A112358
Rusty
Middle of Nowhere Arizona
2025 Maverick Hybrid AWD
What size and threads are the screws/bolts to fit the holes?
smoreho2
Virginia
2023 XLT Hybrid (October 2023)
Link to d rings you used?
Tbone289
Nice solution.
You may already be aware, but a DIY strut channel rail system can be had for less than $100 using the same threaded holes.
Jock
Rodger
Camden NY
www.mavericktruckclub.com
2000 Mustang GT rag top 06 VW GTI 18 VW Alltrak
I did the same on my my26 and it worked out well picked up on Amazon
Bolts are M8x1.25 had to use a M8 tap to clean out the holes from the sprayed in bed liner.
where did you get them and what size are the screws
Xbert
New York
2026 maverick XLT AWD
Got them from Amazon. M8x1.25
sorry I got the screws from my local Hardware store I got the tie downs from Amazon
Xbert
New York
Heavy Duty Truck Bed Tie Down Anchors Rings Trailers Hook Cargo Bolt on V Ring Pickups Rail Accessories (4 Pack)
Got the screws at my local hardware store M8x1.25
Also I had to use a tap to set the predrilled holes in the bed because I had a sprayed in bed liner.
You may or may not have to do the same. It's pretty easy.
M8 x 1.25mm Metric Tap and Die Set, HSS Machine Thread Tap and Round Die for Right Hand Threading, Ideal for Nut and Bolt Repair
Sorry I haven't figured out how to create a link yet.
