Bed Tie Down Bolts
bassfishinagain
2024 Mav XL no options but hitch and hybrid
I've added a couple extra tie down in hte back on my XL and want to add one a pair of D rings to the floor near the cab i nthe two existing holes. But I need to buy bolts for those. Can anyone tell me the correct bolt size / thread / etc. I need to get at ACE?
Only post I could find said a T40 bolt and that is not enough detail. I need something like M8 10MM T40 3/4" or something similar. I know on the back ones I had to clean out the threads before I could get the bolts in - likely the same here?
Thanks!
MAVRICK
Any
2024 XL
CREDIT: Sam Haymart [Test Driven TV]
Parts Needed:
Keeper 2 3/4” Oval Plate Recessed Anchor (Part #89312) (2x)
M8 x 1.25 Torx Head Bolts (4x)
bassfishinagain
I'm guessing he means 1.25" but it is not 100% clear.
Gschaef
Maverick XL
I used these for those same floor holes. Two for each one. I had a spray in bedliner and I did need to tap the holes.
M8-1.25 x 25mm
bassfishinagain
M8-1.25 x 25mm
Thanks - perfect - I'll pick some up and hopefully they work. If I have to dust off a 25 year old Tap and die set they it could be trouble :)
mykoleary
Myk
Puget Sound
2024 Maverick XL
Any reason everyone installs d rings in the floor instead of two 1000 pound triangle tie downs in the same holes?
icegradner
British Columbia, Canada
2022 XLT Maverick Hybrid
The D-rings lay flat, so if you have big items they don't get in the way. Unless I'm misunderstanding the different between the tie down types.
mykoleary
Myk
Puget Sound
2024 Maverick XL
I found a set on Amazon that lay flat and used them on the sides of the bed instead of the DIY channel strut rails.
Was going to use them on the floor bed too.
https://a.co/d/11cyWHs
icegradner
Yeah that's kind of the same type, just a different shape. I thought you were talking about tie downs like the ones at the back sides of the bed. My mistake.
