Changing out engine air filter today
Maverick2023
Kip
Atlanta, GA
Toyota Rav4
The air filter is a bit smaller than I thought. As you can see after 2 plus years it’s accumulated quite a bit of dirt.
Ford Maverick Changing out engine air filter today IMG_4422
shrek
Jon
Alhambra, IL
2024 Mav Lariat Lux FX4, 4k tow
At first when I read 2 years I was like HOLY $H!T, but; then I noticed you have a hybrid. I understand now.
I replaced my filter at 15K (7 months) But I have an EcoBoost. Mine looked just like that; maybe even worse. Sometimes I wish I would have gone with the Hybrid.
But..... The negative posts about deep sleep and such forced my thoughts to go EcoBoost; as I already had experience with that engine and tranny on the wifemates 2020 Edge (traded on a 2024 Edge in May) Same exact Engine same exact PTU and RDU. So everything I order for filters and such are for 2 vehicles.
Hope you alls Holidays are Merry Merry and Happy Happy!!!!
Old Fart
Mid Florida
2022 Ford Maverick XLT; 2016 Prius ECO
The filters at Wally world don't fit even though it says it's for the Maverick, I have the OEM, I'll try the acetone because the Stealership is getting $30 bucks for a new one. Tired of getting spanked.
Maverick2023
Maverick2023
Kip
Atlanta, GA
Toyota Rav4
Please ignore my post about the acetone. I know nothing about chemistry. I paid like $19 for the filter from Amazon.
shrek
Jon
Alhambra, IL
Yeah hybrids have no need for regular maintenance and clean filters.
Well the ICE does not run as much as ours............... If they are City Divers, they might have 15K on the ODO, but the ICE ran 5K. Make Sense Now?
shrek
Jon
Alhambra, IL
I do "Get it". Mine looked the same after 15K in 7 months. So ya......... Dunno what you do. But I look at mine every oil change. That's NOT bad at all. Seen much worse. Much Much worse. Hell I got a 2018 6.7L Diesel. Looks like that after 8K. Milage and use are what I go by. SHIT. If I changed mine everytime I had a lil discoloration (gots look at the other side) I would change every 5K oil change. You do you, Ill do me. That Dudes Filter on a Hybrid looks decent for what it is. I dunno, If there is nothing on the clean side I go with it. Who else does not do the same? Speak up folks. Do you Change your filter after its a lil dirty on the Bottom side? Or do you wait?
I would love a consensus at this point.
And If you work at a Jiffy Lube or a quick lane; PLEASE DON'T chime in. I know your tactics.
I had a guy come out with a filter that was NOT sized for my vehicle (FORD Quick Lane). (Round cylinder vs FLAT) Tried to tell me I needed a filter. LMFAO! I was like; "Show me where that filter goes in my Car" We Walked out to my Crown Vic and I saids "Okay; show me"
He was Like "I guess; it was the other vehicle in the bay" I was like "Thats a 5.4L Triton Filter; None were in the shop"
He walked away; tail between his legs!
Tim d
Alpena
Ram
As per my earlier post, my classic car has a filter in that's 35 years old, granted it doesn't get used nuch.the k&n filter in my ram is over 15 years old, I know that's reusable. Our mavericks filter is almost 3 years old and 27,000 miles, doesn't look bad,I blow it out with compressed air every spring. will probably change it in a cpl more years at 40- 50 thousand miles.
Old Fart
Mid Florida
I remember the oil bath air cleaners, you could pour off the oil scrape the crap out of the housing rinse the element out in the Zep tank reinstall everything with fresh oil, used to be a great filter, though messy, both of my mid 50's Pontiacs had them on top of a hooking 348 cid V8.
F150 2.7 TT user
Kenneth
SE WI
2026 Maverick Tremor, 2017 F150 XL 2.7
Many options affect this topic. I had cars with oil bath filters 1950s style. The engines loafed along with loose tolerances from the factory and coarse filters worked fine. High performance Muscle Car ear with big circular filters of tighter material for he clearances used. These are fine up till computer machine tolerances needing tighter filters. Then there is the use of turbocharging. Even small dust paricles that impact the very high RPM turbines embed onto the blades and will hater more dust particle that can grow to the point of being able to cause damage. On turbo vehicles it is not dust into the cylinder but dust building up in the turbo.
I have used a lot of open free flow filter setup on NA vehicles but will not on a turbocharged one!
"consensus" ain't gonna happen to many stubborn folks. If I ever go back to a NA breathing engine I would not worry much about the air filter. But I have seen dust build up downstream in intake piping with K&N and other free flow filters. Turbocharges in my use will get better care.
As to frequency I'll inspect my air filters several times a year, not so much for dirt as dirty filters filter better than new, but for fit and condition. Yes looking at the clean side it should be clean, the dirt side is good as long as obvious plugging is not visible. Another point is electronically controlled engines do not respond as the old carb and point ignition engines. The ECU determines the power demand and adjust itself. Tossing a free flow or no filter at all in the airbox just increases the air flow potential while the ECU decide what to do with the air available. Ya need to allow that ECU to demand more power to get any, that is called tuning!
BK007
BK007
OH
🤷‍♂️ Just like what oil you use everyone will have their opinion on what they like and dislike. Just use whatever filter you like to use and change it when dirty pretty simple.
