CEL: The Engine control system has reached its adaptive learning limits with the fuel control system.
shurmanter
Massachusetts
You would get this code if you put E85 (85% ethanol) in the tank. MPG would also go down by 30%. But maybe 10-15% if you only added half a tank.
The nice thing is, it will all return to normal once you use it up and put in stronger gas.
Definitely wasn’t labeled as E85. Tbh I’ve never actually see that at a station as I don’t think that’s a thing up here in Massachusetts.
I DID fill up yesterday though…
shurmanter
Massachusetts
Probably not but on the more dangerous end could be a leaky injector or fuel line issue. I would definitely give it a good sniff under the hood for fuel smells and get it to the dealer soon.
I was looking under good yesterday and didn’t smell anything
NeedForSteve
Eastern NC
2007 Fusion 2.3; 2023 HPR XLT EB
being this new, I'd lean toward something inducing a vacuum leak, like maybe a faulty CPV. If you're still under warranty there's no reason to futz around with it yourself. Take it in and let them document the issue.
shurmanter
Massachusetts
Absolutely is my plan. Just wasn’t sure if others had seen this could help me help point them in the right direction. No idea about a loaner from then and I need a vehicle, so time is limited.
VBMav
Indiana
www.theveteranscheck.com
2022 Maverick XLT; 2025 Escape PHEV
Would the computer report something like this if the fuel "cap" didn't close all the way? This would prevent the hybrid fuel tank from pressurizing fully from what I understand.
GPSMan
Many
Different code.
Ozarkbeard
That fact would've been good to put in your original post.
I've had CELs come on after filling up with "suspect" gas. Make sure you fill up with "Top Tier" fuel. And if you have it, try using what we call "real gas" around here. It is ethanol-free and usually pricier. However yesterday, it was down to $2.49 at a station near me. So I'ma switch to it for winter driving. Regular 10% ethanol fuel is down to $2.35
shurmanter
Massachusetts
Yeah. Prices are still over 3 here.
I totally get your sentiment about the fillup and certainly could be contributing but I did notice previous tank was lower mpg than is typical, so wasn’t thinking it was that.
P0171 System too lean bank 1. Any ideas about this.
TSB. 23E07 is software update for oxygen sensor to fix possibility of running with non optimum efficiency. At least that's what my recall notice said
Reread notice "heating element used to warmup emissions control sensor is not working due to a software error".
Maverickman74
Shane
Maui HI
Well thats good. You never know when a rat will decides it want to chew on something.
colinl
Colin
ICT
my money's on a bad injector. Running lean heats up the cylinders, don't go running it hard.
I agree, especially with the advice to NOT run it hard. If the code is lean, you do not want to drive it hard. There is a limit to what the knock sensor can do and if it's pushed hard when lean, it does not take a lot of detonation to cause significant damage to the piston.
Mike_Sam
Ottawa, Canada
2023 Maverick XLT
I had this happen on my Transit Connect. The dealership tried to say that since it hadn’t been driven much (i.e., 4000km over 8 months - long story), that it was an accumulation of old/stale or bad gasoline. After a few full fill ups (with “fresh” gas), the problem persisted, so they changed the Mass AirFlow sensor. Since then, I never had the problem again. So I guess it was the MAF sensor.
