CEL: The Engine control system has reached its adaptive learning limits with the fuel control system.
shurmanter
Massachusetts
Being stock, and driving like a grandpa has nothing to do with it. Stuff fails anyway. :ROFLMAO:
No of course. More what I was saying was, it wasn’t something self induced. I’ll check under the hood for lose/broken as I’m a tradesman so am semi-competent but not a car mechanic and certainly not trying to troubleshoot/repair
ndmiller
Noah
Atlanta
2024 Maverick XLT Azure Blue Metallic
Take it out on the highway and drive it NOT like a grampa and blow the crap out of the engine. Get it warm then HOT and thrash it a bit. Maybe a 5-15 miles driving over the speed limit with some full throttle for good measure.
shurmanter
Massachusetts
So you’re telling me on my 45 mile commute tomorrow to put in sport mode and HAVE FUN?
Automan21
Mel
CT
‘23 XLT Eco AWD 4K Tow
Yeah, id try that. Sometimes it just needs to get a good heating up if it is the o2 sensors.
shurmanter
Massachusetts
Ok. I typically run it pretty conservatively as I’ve decided I don’t want to pay more on gas than I have to with a 90 mile round trip commute, but I can certainly open it up.
ndmiller
Noah
Atlanta
Don't go crazy, but full throttle merge on the highway with a little high speed running to heat up the exhaust and clean the O2 sensors. Hybrids are great for gas mileage, but not necessarily good for ICE engines and their parts as they don't work as hard under normal driving.
shurmanter
Massachusetts
Yeah I wasn’t planning on being crazy at 5am just thinking I’d drive like everyone else. Lol.
MAVRICK
Any
2024 XL
^^^^ ... It is technically (and respectfully) referred to as a "red neck tune-up". o_O
Tiger Dude
Skip
Louisiana USA
2023 XL
my money's on a bad injector. Running lean heats up the cylinders, don't go running it hard.
shurmanter
Massachusetts
As I’m not a car guy…
That sounds bad. I’m not planning on running it hard. Just not strictly cruise control speed limit.
CD_SM
San Diego, CA
Mazda6 '06
I got this code when the mass airflow sensor was flaky on my Mazda 6.
GPSMan
Many
You would get this code if you put E85 (85% ethanol) in the tank. MPG would also go down by 30%. But maybe 10-15% if you only added half a tank.
The nice thing is, it will all return to normal once you use it up and put in stronger gas.
Stock411
HI
2022 Ford Maverick XLT Hybrid
I was about to say too, bad gas.
Years ago I had a Lexus that got lean codes. Turns out I put E85 when on the manual it says not to use E85, whoops. Paid for crazy amounts of Diagnostic time and even swapping parts, turns out it was bad gas for the car.
Maverickman74
Shane
Maui HI
Probably not but on the more dangerous end could be a leaky injector or fuel line issue. I would definitely give it a good sniff under the hood for fuel smells and get it to the dealer soon.
