Cabin air filter replacement, paper found on top of filter.
MaverickSVT
Ohio
2000 Ford Contour SVT
Pulled the cabin air filter out of a 2023 Maverick Hybrid and to my surprise, had this come out with the filter!
This is a first for me to see a piece of paper like this come out. I wonder if it came from the factory this way? Like it was just accidentally left in there during assembly?
Filter was dirty. Truck has under 30k miles
New replacement Motorcraft cabin air filter
FP-100-A has a noticeably more filter pleats.
I’m sure it will filter better, but I wonder if it could slightly restrict the airflow of the HVAC where it will not blow as hard or make the system have to work harder? I did read that those aftermarket charcoal activated cabin air filters can be too restrictive on the system.
Probably best to stick with OEM cabin air filter is my thinking.
Ford Maverick Cabin air filter replacement, paper found on top of filter. IMG_3341
MaverickSVT
MaverickSVT
Ohio
And here is my 2022 maverick’s cabin air filter
Mine was cleaner. With a very district and sort of strange in comparison to the 2023, the odd dirt pattern on my 2022.
I really don’t use my AC much which would probably affect how dirty it is overall.
Ford Maverick Cabin air filter replacement, paper found on top of filter. IMG_3247
Cancunbadlands
Cancun
Cancun
Nesting?
Johnkn
MD
Did you purchase the truck new?
That looks like a dryer sheet on the old filter (to freshen air?)
I tried an aftermarket charcoal filter on one of my Raptors and immediately removed it as it restricted flow ~50%, OEM works just fine...
good luck
Johnkn
MD
^^ Mine were from Amazon, lesson learned..,....
MaverickSVT
MaverickSVT
Ohio
Bought new. Never replaced
It was not a dryer sheet
commadorebob
I'm not an expert on the air intake for the A/C, but could it be something that was just sucked in as you drove? The whole point of the filter is to filter crap in the air and I see stuff like that floating around the highway all the time.
Tim d
Alpena
Ram
Mine out
I was going to throw mine out and not replace it since I drive with the windows down sometimes but apparently this filter protects the heater and hvac system. Buy aftermarket, its half the price of the Ford filter.
Escapologist
Niagara Region, ON
good luck
Just a note about filters in general, anything that claims "High filtration efficiency" is not gonna have high flow efficiency, and mostly vice versa. Though there are some convoluted and bulky ways to do a bit of both, in general it's a tradeoff.
MaverickSVT
MaverickSVT
Ohio
Mine out
The OEM motorcraft was only 18 bucks
That’s the same price as aftermarket
Chops
Lobo
My 2025 has the new Motorcraft filter you have pictured. Seems the early model years had a “cheaper” filter?​
Johnkn
MD
Because you have to pay for someone to put it in. It literally takes a minute to install. Don't pay these thieves to do it.
$40 total charge to install an $18 filter represents a thief?
It appears he was charged for ~10 minutes of labor...
