Brake pad replacement
Decayed
yes
a car
Anyone do brake pads yet? Does this thing need a scanner to retract the caliper pistons/recalibrate the caliper position or can you just do it manually?
Montana
Thread should be a sticky:
https://www.mavericktruckclub.com/forum/threads/brake-pad-replacement-process.33381/\
Definitely check to make sure yours can enter brake service mode. There is an SSM because @Ford Motor Company refuses to make it a TSB for ones that won't go into service mode, so the only option is FDRS. Forscan will not work.
You do not need to enter service mode for the fronts. But there is a thread with reports of people including myself that cannot get their trucks to enter service mode, and the service dept. did confirm it being an issue.
SSM 51217.
I suspect the issue is more than '22's alone, but considering how many people will just pay someone 400% more for an hours labor, don't expect a fix.
Bob The Builder
Butch
Vermont
I will probably be finding out sooner than later. One of the first things I would like to do is install Ceramic pads on my Maverick. Front, at least.
Montana
Here ya go:
https://www.mavericktruckclub.com/f...ick-22-lariat-lux-fx4-4k-eb.33672/post-614984
My post with a bunch of parts including the brake pads I got. If you can find them elsewhere to avoid Rock Auto shipping, I recommend doing that. But I could not find them on Amazon when I was looking and everywhere else wanted shipping too. Napa is the only option near me and they wanted almost triple for a set of pads I've never even heard of. Hell to the naw. Happy to report the rotors on the Maverick are holding up much better than the ones on my Escape were after a year and a half ;)
Decayed
Decayed
yes
a car
Here ya go:
What's the advantage of ceramics over semi metallic? Is the rock auto chart accurate saying they have less dust and noise but don't stop as well? Does the mav comes with organics?- mine create a hell of a lot of dust since I do tons of stop and go driving. It would be nice to cut down on the dust.
BlueRaven
Iowa
24 Mav, 01 CRV
ceremics are 10 times better than metallic or semi-metallic pads. why any company still makes those garbage pads is beyond me. and shame on ford for using them. i got mine from oriellys. have been on for over 11000 miles. no dust on my good wheels and shorter stopping distance.
LC48
Johnson County Texas
SSM 51217.
How does this square up with the "Right to Repair"? @Ford Motor Company ?
Houndmav
VT
23 XL Hybrid
Thanks for this. I long for a simple cable e-brake…
Decayed
Decayed
yes
a car
My old explorer has that. It's a surprisingly simple system. If the computer or battery goes on the mav I guess you won't even be able to put the brake on.
Old Ford Guy
Rod
Northeast Ohio
2024 Maverick Hybrid Lariat ; 2016 Linc Navigator
i was wondering the same thing about ceramic vs organic pads. also since mine is hybrid i'm curious as to how much or little effect regenerative braking will have on brake pad wear. my guess would be less pad wear but i have no idea if thats correct or not.
RedRider
Kitchener, Ontario, Canada
You have to replace your pads already? How many miles did you get on the old ones? Did you have to swap them because of a seized caliper or do you just do ultra-hard braking all the time?
Ozarkbeard
...since mine is hybrid i'm curious as to how much or little effect regenerative braking will have on brake pad wear...
Regen reduces brake pad wear a lot. Someone posted (either on here or the reddit subforum) that their 2005 Escape Hybrid's brake pads lasted 200,000 miles.
Waterick
Laurens county SC
Regen improves brake pad wear a lot. Someone posted (either on here or the reddit subforum) that their 2005 Escape Hybrid's brake pads lasted 200,000 miles.
If our Prius (es) are any indication, (still no Maverick) with the regen braking there is no dust problem either.
Decayed
Decayed
yes
a car
It depends on whether the regen system needs the brakes engaged to work. It's probably going to be less either way.
