Bluetooth connection FINALLY FIXED with newest software update!!
aspect
BC, canada
XLT Lux FX4 2.0 4k
My phone would always eventually drop the bluetooth connection, forcing me to awkwardly use my speakerphone, if I drove long enough. Sometimes I could watch it disconnect, and then re-pair, while I was driving. I tried fully re-pairing from scratch etc, and this *seemed* to help sometimes but it would never stick.
I installed the newest software update a couple weeks ago and I am happy to report that the bluetooth connection has been bulletproof ever since! I've had exactly zero disconnects and every single time I go to place a phone call it's worked as expected.
Yes, this is pretty much the minimum standard for all vehicles from the past 10 years...but I'm still very happy.
mamboman777
Josh
NRH, TX
Yes. The software update didn't add features that I have noticed, but it did fix this. Worth it.
MrCigar
2022 Maverick XLT EB FX4 Cactus Grey
Silly question I am sure, Maverick for me is two weeks away, how does one get software update?
paneubert
Seattle
2 weeks away from being built? Or 2 weeks away from delivery? it would come with it if it was the current version when the truck was produced. If you don't have the current version, you would need to run the update request when you have the truck in your possession.
Renho17
Ren
Hybrid Mav
Not sure when it was released. I just ran it about 2 weeks ago.
so mine drops everyday and has for almost the 6 months I have had it. I updated it when I first got it tho and it still happened. When I update my iPhone to newest releases it gets better but still. Not so much with iOS 16 but Now with iOS 16.0.3 it’s happening daily. Even on 5 min trips. So can you look what build yours has in it?
and how old is your truck and how many times have you updated it?
Renho17
Ren
Hybrid Mav
On the infotainment screen on the settings section. You need to hook it up to Wi-Fi first then tap search for updates
MrCigar
Two weeks, or less, from delivery. It's currently making its way across AZ as of yesterday headed to CA.
paneubert
Seattle
If it were me, (and it will be eventually), I would dedicate an entire day to going thru every menu to customize my settings. Including parking close to my home Wi-Fi and repeatedly pressing the "check for updates" button. I'm probably going to run thru an entire tank of gas just idling in my driveway. Haha.
MrCigar
Hahaha, I may just sit in it for hours thinking I won the lottery, somehow she made it home!
in the infotainment menu, I think under settings, you can connect to a wifi network. you need to connect the truck to a wireless network in your home - if the signal is strong enough in your garage or wherever you park - or you can set up a hotspot on your phone. the updates are not that large.
then you go in and check for updates repeatedly. seriously, a lot of people have posted that they connected to wifi, checked for update and nothing. and then they did it again 2-3 more times and viola! there's an update being downloaded.
if you have it connected to a wireless network that it can always see when you're parking, it can update itself. that's the idea. but in reality, most people will need to manually check for updates and do them.
aspect
aspect
BC, canada
XLT Lux FX4 2.0 4k
I've had another update in the past, earlier this year. My truck is a little over a year old. This update just came down a few weeks ago. I don't have the version number handy but I'd strongly recommend trying an update and see if one shows up.
I will say that the ONLY way I've gotten my truck to see an update is by tethering to my phone wifi (and even then I had to check a couple times). When connected to the wifi at work or home, it didn't see the update. Maybe the connection isn't quite good enough outside.
Either way, if you've done an update before then I'm sure you can get this one to work.
Renho17
Ren
Hybrid Mav
sweet I will check. Thanks
