Black Replacement One Piece Maverick Lug Nuts
raymaines
Ray
Tacoma, Washington
Alto Blue Lariat Lux Hybrid
I now know more about Maverick lug nuts than I ever thought a person would have to know so I thought I'd share my new-found expertise with you.
The stock chrome lug nuts are two-piece affairs, meaning the basic cheap, ugly lug nut is wrapped with a chrome cover and that can become a problem. Over time water can come between the actual nut and the chrome cover, which can then freeze, expand, corrode, and deform the chrome cover to the extent your lug nut wrench will no longer fit over the nut and thus, makes removing your wheels next to impossible. That's a real drag if you're trying to change a flat time. The cheap, easy answer is to replace the stock lug nuts with one-piece nuts while you still can.
Size: M14X1.5, but that's the easy part. They have to be the right shape as well.
Pictured below are the wrong lug nut, the stock lug nut, and the proper replacement lug nut.
Ford Maverick Black Replacement One Piece Maverick Lug Nuts PXL_20230105_213207792
The right black replacement one-piece lug nuts can be found here:
steeda.com/steeda-555-6603-s550-factory-style-lug-nut-kit-black?fbclid=IwAR3fa_uBtvRTCA5yrO5LxmcxbHURfjtjMDX9uxyKMaj7PAibaq0atWVPXro
Ford Maverick Black Replacement One Piece Maverick Lug Nuts PXL_20230105_214034985
AltoBAP
Jefferson
Metro Detroit
2020 Ford Fusion SE 2.0 AWD
Nice!!!! Thank you for sharing.
paneubert
Seattle
Bushpilot
Greg
Spokane, WA
Chevy Volt
That top nut needs a touch of Sharpie.
Atlas747
DJ
Syracuse, NY
'22 Suburban, '23 Mav XL 2.0 (Est Build 11/28)
Mr. Expert, do you believe they will work with painted steelies? Thanks
MikeyG
phila
So will these one’s for the XLT wheels? Also in the pic is one of them already chipping?
CZaugg
Curtis
Rio Rancho, NM
2023 Maverick Lariat Hybrid, 2021 Toyota Venza
I bought these: https://www.amazon.com/dp/B00DIX0ZSS?psc=1&ref=ppx_yo2ov_dt_b_product_details
These are highly rated and resistant to chipping and scratching. However . . . these are NOT exactly like the OEM that came with the vehicle. They are better quality BUT come with a price. Note that when looking straight on you can see the silver metal of the wheel rim bordering the lug nut. I like that little silver/chrome accent border around the lug nut. Not too much like OEM lug nuts. So if quality is what you want and don't mind paying more AND don't mind the aluminum accent bordering the lug nut, then go for the McGard 64074. The border around the lug nut compliments the brake disc.
Ford Maverick Black Replacement One Piece Maverick Lug Nuts IMG_0032 (1)
Ford Maverick Black Replacement One Piece Maverick Lug Nuts IMG_0033
Ford Maverick Black Replacement One Piece Maverick Lug Nuts IMG_0076 (1)
Slick-rides
Phil
Ohio
2023 Maverick XL
Gorilla 61148BCX is what you want for factory aluminum wheels. These have the large, wide 60* seat like OEM and aren't cheap ones that chip, rust right away. The wide flange also conceals the bottom shoulder of the wheel hole that usually isn't painted from the factory.
Ford Maverick Black Replacement One Piece Maverick Lug Nuts gor-61148bcx_oh_xl
Jamers99
Jason
Tampa, FL
2023 Maverick
So does Gorilla make a spline type lug nut that will match the Maverick factory lug nut size or is this too short for that? I know the lug nut thread is M14x1.5 but it is not clear what the length should be. I'm finding lug nuts in various lengths. What is the factory length?
Ford Maverick Black Replacement One Piece Maverick Lug Nuts Image 4-25-23 at 6.16 PM
Ford Maverick Black Replacement One Piece Maverick Lug Nuts Image 4-25-23 at 6.00 PM
22MavXLT
NC
22 Mustang GT, 23 Maverick XLT AWD
I put my Steeda black lugs off my Mustang on my Maverick and they are 1.4" long I believe. They are also the 2 piece lugs and not the 1 pc as I didn't want to spend that much for lugs when I may eventually change wheels and have to change lugs then anyway.
MetalThunder
MetalThunder
Blue Water Area / Thumb Coast "Mishigami"
www.mercari.com
2024 Iconic Silver AWD XLT 4K Lux Ecoboost
barbara
Barbara
Arkansas
Ford F150
barbara
Barbara
Arkansas
Ford F150
I have a 2023 Maverick Hybrid black appearance package and want to change my chrome lug nuts. My tires are 225/60R18 which came on truck. Would these fit ? I want matte black finish.
Mav_RICK
Rick
Arizona
Ford F150
Barbara I am using these right now. I live in Arizona so I don’t anticipate the rusting issues here. These look decent but don’t cover the chrome entirely but certainly improve the look. They can be removed before taking your truck in for tire rotation. I worry that the shop would mar up the actual black lug nuts anyway. Not sure I want to rotate my own tires. Another plus’s is they are only like $12
MIKKUPPA 24PCS Lug Nut Covers -... https://www.amazon.com/dp/B0BZYZLX33?ref=ppx_pop_mob_ap_share
