Biggest tires for TREMOR
ejgroth2620
Ed
Bradenton, FL
2023 Maverick Tremor
Here is a list of tires for the non-tremor Maverick.
https://www.mavericktruckclub.com/f...-will-fit-the-ford-maverick.7776/#post-160417
If the tire fits the non-lifted truck then you would be good for sure. They list some tires that rub a little or that need some trimming, or that fit with a 2" lift.
When that post was made there was no tremor's in the wild yet so nothing was posted about it. But this should give you a good place to start on thinking about tire size.
Rim offset can have a big impact on fit if you are thinking of aftermarket rims, so be carful about that too.
Do you happen to know how larger tires affect the speedometer/odometer or if any adjustments are needed to have accurate numbers?
Rivers90
Ben
XLT Tremor, Miata
Larger tires would affect the speedometer/odometer. I don't know what can be done about it. Mavericks come with different size tires so there must be a way for the computer to be adjusted.
Maybe forscan can do this but I don't know and have not tried.
A small tire size change may not matter much but IDK.
paneubert
Seattle
The larger tires only marginally mess up the speedometer. In my case, stock XL tires are 225/65R17 and I went with 245/65R17. Doing what the truck says is 70 MPH on the freeway is really 72.5 MPH.
More city related example. Truck displays 35 MPH and I am actually going 36.2 MPH. Not a huge difference.
I've driven past a ton of those "your speed is...." radar signs and they tend to be within 1 MPH of what my speedometer says.
Reference: https://tiresize.com/speedometer-calibration/
Forscan can be used to adjust the computers tire circumference factor in a field.
Rivers90
Ben
XLT Tremor, Miata
As people have more time to do upgrades we will see more big tire Tremors.
The Maverick is light for a truck, that should help it off-road a lot.
