Big MPG shift
AutobahnSHO
Will
S.Carolina
Maverick, Miata
It's 3 degrees back at my hometown this morning. We started the car, scraped any ice off the windows (2-5min), got in and drove gentle.
It's ALWAYS been best practice to at least bi-weekly drive fairly intense (highway speed) for at least 20minutes to keep any car/truck engine performing its best.
Idling more than 5min is a waste of gas with no gain.
Silver23
2023 Ford Maverick Lariat
I've been 46-47 mpg consistently until lately when the weather has been in the 20's. I start it up and let it warm up for 15 min. and this knocks the mpg down to 36 mpg. The Escape that I trade in gave me 32mpg in this weather. My opinion of the Atkinson engine is kaput, cold weather must knock down the compression ratio reducing power.
It's probably because the hybrid battery is cold. It has to warm up also to perform good.
Rlward
Hanwell, NB Canada
Honda CR-V, Fird Maverick XLT Hybrid
Only need five minutes or less. Remote start while you are putting on your coat. Use the heated seat and steering wheel.
dalola
Retired
SE Ohio 🇺🇸
lol.....my 10 minute remote starts in the winter are for ME, not the truck! 🤠
BluegrassNbass
Clif
Washington
2023 XL Hybrid
Finally made it back to the back roads. Don't rush me while I'm hovering along in my Fighter Jet Maverick. I could've done better but sometimes the afterburnerfoot kicks in. And the heat was on too.
Ford Maverick Big MPG shift IMG_20231127_141526
2lbgill
2lbgill
Don
Upper Peninsula MI.
2023 XLTHybrid
no heated seat or wheel. The engine is week on making heat, using less gas makes less heat.
No heated seat or wheel, using less gas results in less heat The Atkinson engine is a fair weather engine. That's why it isn't used in regular applications and only hybrids.
pigsareus
Farmington Hills, Michigan
Maverick XL Hybrid
those are my stats pretty much exactly and I don't warm it up - mileage definitely drops in the winter, I'm in Michigan and your numbers are the same I get. It's just how it is.
Rlward
Hanwell, NB Canada
I get very good heat from my Maverick Hybrid. Quicker than my Honda CRV I believe. Sounds like yours does need the 15 minutes warm-up.
jski
Jon
central wisconsin
2023 Maverick Hybrid Lariat
1st I bought a lower priced Hybrid with all the features I wanted and only cost $35k, much less than buying any other Hybrid Truck out there!
2nd I save so much with great 40-45 MPGs for 8 months of the year I really don't care if I'm burning gas with no MPGs for 3 or 4 months & getting 35 MPGs
3rd What's it cost to warm up my baby for 10-15 minutes? Yes I said 10-15 minutes depending on the weather... it was 13° this morning! 25¢? So 5 days a week X 4 months=80 days X 25¢=$20 x 10 years = $200 (I'll keep it until me or my mav dies or at least 10 years whichever come first)
4th I saved more than that $20 in 1 month just on the cost of my fantastic Maverick compared to ANY other crappy 40-80k hybrid out there.
Please note: you can pick apart my math & or my way life but I don't care... I love this truck!!
Signed warm & happy
Ozarkbeard
...Way too much wet coming in on feet and open doors. Running defrost helps but only if you have a longer drive home. I don’t.
If the Maverick's humidistat detects high humidity in the cab and if you have the HVAC system on, it's gonna run the A/C compressor, regardless of whether you turn it on or not.
Ozarkbeard
... I bought a lower priced Hybrid with all the features I wanted and only cost $35k, much less than buying any other Hybrid Truck out there!...
I bought an even lower priced Hybrid with all the features I wanted, for $12k less than yours.
Despite a mpg drop in winter, the overall MPG and reduced maintenance cost of this truck is incredible.
I believe that you're truck is behaving normally.
A cool down will primarily use the HVB (high voltage battery) which will only run the ICE (internal combustion engine) when the HVB has become depleted.
A warm up will always run the ICE more because the ICE is used as the heater. The heater is a heat transfer from the exhaust and is used not only to heat cabin, but also battery system. The ICE will run in a warm up, even if climate control is off. The truck is unable to warm up using the HVB.
To me the most surprising thing is that you've been getting 46 mpg while remote starting the truck to cool it off every day.... In my book, that's remarkable.
He stated he only turns AC on if ambulant is 95°!
Similar threads
