Beware if trying to rent trailers or towable equipment
jchookas
Royse City, TX
Ford F150
Just a warning to any of those out there that think you can actually make full use of your 4000 lb tow rating... Apparently Home Depot has a policy that won't let you rent any of their heavy equipment unless you have a half ton truck. They don't care what your truck tow rating is. Kind of a huge disappointment since it makes the truck less useful for me. I haven't been able to find another tool rental company in my area that has what I need, hopefully they don't have the same stupid policy.
Any others run into similar issues?
Brian_J
Akron, Ohio
'22 HPR Maverick AWD 4K LUX
Interesting. Just sounds like my money will go to another store.
710-oil-614
Cal
2025 Hybrid AWD Lariat
Absolutely not. I rent from my local HD all the time. Log splitters, concrete grinders w/trailers. I'm not sure if these are classified as "heavy" equipment but they definitely push near the 1,250 towing capacity of my Forester and cause it to squat significantly.
I also have a 2" Curt hitch I installed without a harness and never been told I cannot rent.
Probably because maverick is not on their "approved list" since it is brand new.
Decayed
yes
a car
What do they want when they say half ton? The curb weight is over 3500 lbs for all models and the payload is about 1500 lbs which is more than half a ton, it's 3/4. A ton is 2000 lbs, how much more payload do they want?
Darksider
Here
Two
Uhaul also has a strict policy.. They wouldnt let me pull a vehicle carrier with a ford explorer rated at 5100 lbs even though the vehicle being towed was 2500 lbs. So you might find more issues in the future.
DarkStormy
William
Maine
Nissan Frontier
Exactly, I would just tell the pimple faced HD clerk that I'll be picking up the equipment with my 3/4 ton capacity PU truck.
Decayed
yes
a car
clavicus
No no please, pimple face Jeff is underpaid and just trying to do his job. You gotta hit up Kent, the regional corporate manager and give him what-for.
Deleted member 1370
Guest
Home Depot also rents trucks, while refusing to rent you a trailer your vehicle is rated to tow. I'm sure it is just a coincidence...
My whole point in getting the 4k towing package was to tow a haul for myself to move down south. I hope I don’t run into the same problem. Since the towing requirements were line 2000-2500 lbs according to the site and I thought with 4k they’d give more leeway there
atomguy245
Doug
You see, what you do is buy a new trailer from the trailer store, and DON'T REMOVE THE TAGS. Then when you are done towing, you just return it. Easy.
TooManyVehicles
Upstate NY
15 F150 XLT, 21 BS Badlands, 22 Mav Hybrid
Since a half ton pickup would have a payload capacity of 1000 pounds, show a picture of your payload sticker?
Darksider
Here
Two
I think you all are confusing what a half ton is. A traditional half ton came from old trucks could have a payload of 1000 pounds but had nothing to do with tow capacity. Modern half trucks can exceed this amount. Usually, a half ton truck can haul about 3,000 pounds in its bed and tow up to 9,000 to 10,000 pounds depending on the powertrain.
Which the maverick is not is that class.
Here is the 2021 ford half ton specs.. As you can see the maverick doesn't even come close https://www.google.com/url?sa=t&sou...IQFnoECBoQAQ&usg=AOvVaw0T1v_dQr1eCn8lTDPFdTHX
notfast
Los Angeles CA
What were you trying to rent? If you wanted the skidsteer or the mini excavator, yeah, you'd probably need an F-150-size truck since those things weigh like 7,000lbs with the trailer.
But if you're renting a log splitter, hell, they let me tow one with a Honda Fit LOL.
I'd be asking the same question, but I'm sure it's along the lines of an F-150/Ram/GM 1500-series vehicle or larger.
I think there's more to the story that they didn't tell you. U-haul's algorithm factors in more than just the tow rating of the tow vehicle and the weight of the vehicle being towed. It also factors, among other things, the frontal area of the vehicle being towed, the drive type of the tow vehicle and the towed vehicle, the tow vehicle's wheelbase, and so on.
But I can't think of a 2500lb vehicle that is so nose heavy that the algorithm wouldn't let you tow it with an SUV, which is why I said that I think we're missing part of the story.
And either way, if you want to throw caution to the wind and don't have to show up to the U-haul lot with the vehicle that needs to be towed, you could just claim to be needing to tow a vehicle that the algorithm accepts. I've rented U-haul auto transporters numerous times. There is no way to confirm what I actually towed on the trailer unless I wrecked or got a flat.
You definitely won't have a problem if you rent the trailer after U-hauls database is updated...eventually. If you have to rent before then, you might have some explaining to do, but I don't see why they wouldn't let you take it. Hell, a Toyota Corolla is permitted to tow the 5x8 enclosed.
I think some folks are poking fun at the fact that "1/2 ton" is a colloquial term now, and the Maverick hauls, well, more than half a ton.
Dunno what "half-tons" you're looking at, but the maximum possible payload for an F-150-type truck is 3325lbs. And that is a far outlier of a truck in its category, since it's the F-150 regular cab, 8' bed, 2WD, 5.0L V8, with the heavy duty payload package. Those are typically not found on dealer lots. Maybe if it's a high volume dealer that sells a lot of work trucks.
A more common F-150 crew cab 4x4 5.0L V8 with standard payload hovers around 2,000lbs or less. The "maximum" payloads listed in the chart below are for basically the stripped-out version of each truck. Getting an XLT with all the options checked off would further reduce the payload capacity.
https://www.ford.com/trucks/f150/models/f150-xlt/
Decayed
yes
a car
Well it depends on how you define what a half ton pickup is, doesn't it? In any case, the mav is rated to tow the stuff from home depot. It's HD that doesn't know what they're talking about.
