Bed power outlet delete...?
nrcurcio
NC
IL, USA
23 XLT, EcoBoost
I have the 400 watt outlet in the bed. After figuring out that it can't even run a coffee maker, I am considering deleting it. Anyone done this? I searched the forum but couldn't find any threads.
Johnkn
MD
What do you gain by deleting it, other than potentially making the truck a little less desirable at resale?
Search every where for "after market inverter"!
AT THIS POINT I would NOT add or delete anything!!!!!
Mikeetch
Michael
2023 Alto Blue XLT Hybrid Maverick
Coffee makers draw a lot of power. Pretty much anything with a heating element does.
Yep, and/or causing some random electrical issue, fuses blowing, burned wires, who knows what
OB1e
Massachusetts
CG LUX XLT
Tuck the wire back into the wheel well and you can gain a new cubby spot. You need to ziptie the wires to themselves.
Don806
Don
SE Ohio
I moved the bed outlet into a bed cubby, idea from a member here. (Thank you Yds!)The extra bed cubby is nice. Only thing I’ve used either outlet for is to charge power tool batteries.
Ford Maverick Bed power outlet delete...? 69282933895__966114FD-D794-4583-8171-E5FFB95EF226
nrcurcio
NC
IL, USA
23 XLT, EcoBoost
I'l
Like this idea... I think I will try this. thanks much
RLmesc
Randy
Dubuque, Ia
18 Kia Sportage, 05 Porsche Boxster S, 85 Kawasaki
Can I add this with "that" part and the pig tail that is found in the glove box? This is Ingenius. I will say ford missed the point by putting the <---> arrow on the lid of the smuggler's box, any moron will figure out our hiding spot for... Whatever.
Don806
Don
SE Ohio
What did you do with the light and switch?
Light is gone, it only mounts in that plate. Used the switch and light wiring for bed lights I installed. Using the extra pigtail wire that came with the truck (it plugs into the plug the light went into) Just mark the light wire and switch wire when you disconnect, the plugs fit either and it can be wired backeards
Ford Maverick Bed power outlet delete...? IMG_8724
Ford Maverick Bed power outlet delete...? IMG_8725
Ford Maverick Bed power outlet delete...? IMG_8740
Don806
Don
SE Ohio
I'l
Everything just unplugs, the power outlet is the hardest to deal with, wiring is tight. I used the plug for the light connected to the extra 12v pigtail wire that came with the truck to run new bed lights
nrcurcio
NC
IL, USA
23 XLT, EcoBoost
This is great... I'm copying exactly... thanks
