Beach Use
NextTruck
PA
2017 JeepGC Overland, 2010 Tahoe
Has anyone tried to access the beach with the basic AWD set up and no other mods? Loose sand, not hard packed conditions.
gte105u
Katy, TX
Would be careful with stock tires. That'll mean more than the AWD in sand. You can use forescan to unlock off-road modes which should help. But I wouldn't take road tires on loose sand without a good way to get unstuck.
NextTruck
PA
Agree with the tires. I am hoping the vehicle is lite enough that it wouldn't dig in from excessive wheel spin because it does not have low range. Past experience tells me low range allows the vehicle to walk across the sand, versus digging through it. Beach use does not always involve baha speeds and throwing sand like I have seen.
commadorebob
Slippery mode helps with sand. Also, I have found on my Escape "L" stays in 1st gear. It might be the same on the Maverick, but I won't know until I get it.
But as mentioned, fat tires with huge tread will be more important than the slim road tires that come standard. It also depends on the beach. Redneck Riviera, likely not a huge deal as the loose sand is only a couple inches deep. I've seen Rangers fly down the beach on A/T tires with no issues.
gte105u
Katy, TX
Could work, might not... Would air down for sure. Still I'd like to have a buddy there that could pull me, and orient so the drag with the tow hitch is towards the clear to be safe. I get nervous in sand in a 4x4. Would be real nervous with street treads.
Pallyboy
Aaron
Pennsylvania
Wrangler
The right tires for the situation are always key as mentioned.
just my 2 cents for what I have witnessed since not all sand is the same. I have seen every type of vehicle get stuck in the soft white sand along the gulf coast (pan handle). AWD and the like. Mostly tourists who tried to park off of the highway in the sand. Atlantic coast sand seems like it has more shells and larger grains that make it much easier to drive on.
If you’re in an area where other people are driving in sand I would believe the Maverick would do just as well especially with the traction control options.
fordtoughwait
Jonas
Norfolk VA
1999 S10
It's a pain, but for soft sand, bringing tire pressure down somewhere between 15 and 20psi makes all the difference in the world.
NextTruck
PA
I off road frequently in Delaware beaches in a Tahoe or Jeep GC. Both dual range transfer cases. Tire pressure 20-22 psi and I carry Max Trax and proper gear. Never been stuck, but last summer I pulled out a new Silverado Z-71. Wide off-road tires and all. Depends a lot on the driver.
dcs12345
TX
07 Chevy
I plan on using mine on the beach a lot since I enjoy surf fishing. I also plan on keeping an air compressor (in the truck all the time), max trax style board, recovery rope (and related equipment), and small shovel in the bed when I go to the beach just in case.
ShadowBlack XL440
Robert
Northern Ohio
I like to watch Matt's Offraod Recovery on YouTube. From that I have learned there is different techniques for different types of sand. Beach sand is different from desert sand. At least you will have some nice scenery to enjoy if you do get stuck.
dcs12345
TX
07 Chevy
I'm on the northern coast of TX....I wouldn't call any of TX's beaches that "scenic" until you get south of Corpus Christi.....unless you find chocolate milk pretty.
Maverickman74
Shane
Maui HI
Someone said a while back it was the one thing that their pirellis were decent at? Anyways ive taken a pontiac bonnevile on sand before so whatever.
Rivers90
Ben
XLT Tremor, Miata
Sand is where low tire pressure helps the most at keeping you from digging in.
Just air back up when you leave the beach for the pavement.
jesemd
PA
Forester
I would think you should be fine for beach driving, given how many Subarus and Escapes are on the beaches. Watch or read as much as you can on beach driving, have a light touch on the throttle and watch your engine temperature. Your engine can get hot pretty quickly, especially without low range. If you are going into an area that is lightly travelled, I would have at least a come along, some boards and a good shovel to self recover. And when you leave the beach, spend some time under the truck with a hose getting the salt off.
