Ford Hard Folding Tonneau Cover Installed
morrisod
Danny
Carstairs, Alberta
Honda civic
Just received my hard folding tonneau cover from Ford Canada. I had ordered it in June/21 when I ordered my Maverick. I received the truck in Oct/21. The cover was easy to install. Looks and fits great.
oldstudent52
2004 Colorado
Does yours leak? Mine was factory installed and had cracks in the weather strips and leaked in the corners near the cab. Service ordered a new one and installed it. It already had small cracks in the rubber and still leaks.
Halo9x
Hal
Abilene, TX
Maverick XLT 2023
In doing my research before buying any cover, durability was a concern for me since I was only going to get one shot at this. I chose a retractable cover from Truck2Go made by SyneticUSA. Yes, it leaks a little from the car wash but just a little I don’t think there’s any cover that won’t leak some except for the type that lifts up. Here’s some pics.
Ford Maverick Ford Hard Folding Tonneau Cover Installed IMG_0169
Ford Maverick Ford Hard Folding Tonneau Cover Installed IMG_0151
Ford Maverick Ford Hard Folding Tonneau Cover Installed IMG_0073
Fratedog
Fabian
Tampa
2021 Bronco, 2023 Maverick, Bmw F900R, Tiger 660
@Halo9x... Have a couple of questions, if you'd be so kind?
1. Can the tailgate be opened with cover fully closed and locked?
2. Do you lose approx. 9 inches or 21 inches of bed with it fully rolled up?
3. Is it easily and fairly quickly removable after initial install?
Thanks in advance... their website is pretty vague on info.
Halo9x
Hal
Abilene, TX
Maverick XLT 2023
Glad to be of help! The cover does not interfere or hinder the tailgate in anyway. In fact, one compliments the other. When locked, the only way to get in is with a cutting torch!
I’m not sure exactly how many inches you ‘lose’ but it would depend on what you’re trying to load. There is room underneath the retractable box for smallish items.So, it’s not totally lost space. But yes, you’re going to lose about a foot of space at the back of the bed.
I guess it would take about 30 minutes to an hour to uninstall since all you have to do is loosen the clamps. Something I have no need of doing. If you plan on doing that a lot, I would get something else. The retractable cover is pretty much intended to be a permanent addition. For me, if I have to remove the cover, then it isn’t going in the bed or I’m going to have to rent a small trailer to carry what I need.
I suggest getting a cover that would meet your planned bed usage.
Ford Maverick Ford Hard Folding Tonneau Cover Installed IMG_0171
Ford Maverick Ford Hard Folding Tonneau Cover Installed IMG_0170
Fratedog
Fabian
Tampa
Much obliged for the quick and quite detailed answers. I need to think this one out a bit more due to the possibility of needing, albeit rarely, the whole bed.
Cheers, FG
Johnkn
MD
Cheers, FG
Actually that cover, like the Retrax Pro I have on my TRX and Raptor can be removed in ~5 minutes...
There's no need to completely disassemble it like it was shipped, just quickly back off the bolts on the (6) side clamps and lift off...
(y)
Johnkn
MD
(y)
A correction to my post, to only remove the cover, if it takes you 3 minutes you are doing something wrong. No tools needed, fold the cover up against the cab, there are (2) thumbscrews to loosen, then simply lift the cover off. Reverse for installation. There is no need to remove the side rails. But I just removed them as I'm transfering my cover to the new '23 Maverick I picked up Friday. Removing the (2) rails took about 1 minute, one turn on each of the (6) clamps and they fall off and lift the rails off. Again, no need to remove the rails if you just want to remove the cover.
commadorebob
They should grant you a commission as I think this is the one I'm going to end up getting and it is based on this post.
GreenLady
Jeannette
NE FL, NC, SC
Cheers, FG
Call Chris Dove at RealTruck and he will spend time helping you determine which cover is best and be sure to ask for a MTC discount. The first sales person I spoke with sold me a BakFlip MX4 which I couldn’t lift at 71 lbs.! Chris helped me determine the best one for my truck.
Halo9x
Hal
Abilene, TX
Maverick XLT 2023
When you do, please let them know. I am trying to get the word out. I’m very pleased with mine and like to support good products. I was torn between the retract and the hard roll-up type. But after reading about durability issues and the fact that the roll-up was more expensive I decided on the SyneticUSA product. The other brands at my dealership were $500+ more before installation! It is still expensive BUT it’s a purchase I will only make once! I think you’ll be pleased with the SyneticUSA cover especially after you see how it looks and works.
JLUE
Mary Esther FL
I started to order a cover from Ford but I ordered a $200 tri-fold cover from Amazon. It has a small leak in the corner but it fits and looks great. I ordered another $200 cover for my new Maverick which I ordered for my wife.
Ford Maverick Ford Hard Folding Tonneau Cover Installed 16904727848254482102518645897692
