AWD - PTU fluid change
AnnieWaits
I know this is relatively premature, since most of the Mavs on this board have 20,000 miles or fewer, but has anyone looked into how difficult it would be to change the fluid on the AWD power transfer unit? It's not on the maintenance schedule, but these seem to frequently fail on many AWD CUVs, IMO, because of a combination of often being placed near very hot engine and exhaust components, and the manufacturers declaring them to have "lifetime fill" fluid. I'd consider doing it or having it done around the 50k mark.
fossil
ernie
ohio
it's more a function of how hard it's been worked off road
Sleeper 7
Steven
NH
18 Fusion 14 Ram Dump 23 Maverick XL
Someone on here did it a few weeks ago. Easy job on the Mav lots of room. I heard every 30k is recommended. That gos for trans fluid also.
Sleeper 7
Steven
NH
AltoBlueLariat
Minnesota
I changed the PTU oil myself and it was easy. Removing the skid plate on my FX4 was the hardest part. I refilled it by using a clear plastic tube routed from the engine compartment above.
Sjurgen
Shannon
Oregon
Chevy Spark, Toyota Prius, 1973 F100
The hardest part for me was squeezing out the cold oil from the bottle. I placed bottle in very hot water to thin it and it was easier. I swapped to bottle top from the RDU oil bottle and put a small hose on the tip. The job is not that bad.
Montana
LGRW_GoGRG
Trevor
Grand Rapids, MI
Maverick 2022
I had the TPU fluid changed at the dealer at the recommended 30k miles and I wouldn't recommend it. My truck has been a bit jumpy ever since. Probably would have been better to wait for 50k.
801Maverick801
Utah
Subaru Forester
Then they didnt service it correctly. It doesnt even take a quart of fluid. I changed mine plus the RDU at 10,000 miles and I highly recommend others do the same after seeing what my fluid looked like.
Id probably stop driving your truck to be honest until you check the fluid level.
Decayed
yes
a car
30k is for severe duty use which includes frequent towing. It also include frequent stop and go driving which is just about all I do. Otherwise the manual states 60k. Can't hurt to do it sooner though.
LGRW_GoGRG
Trevor
Grand Rapids, MI
Maverick 2022
Welp, I either changed it too early or something else was definitely going on because I just got a call from the dealer and the tech notified me that there is metal in the tranny fluid, so I believe they are doing an entire transmission replacement since I'm still under power train warranty at 41k miles. Not really happy about it because now I'm scratching my head for not getting the extended Granger Ford/Flood warranty. Will post updates once I hear more.
