chrisofpa
Hawley, Pennsylvania
2025 Ford Maverick Tremor
To start I want to give this man a shout out for providing this fantastic wiring harness and auto dimming mirror with garage door opener/compass for the Ford Maverick:
Link to the mirror kit on E-Bay: https://www.ebay.com/itm/126968047760
Link to the mirror kit on Etsy: https://www.etsy.com/listing/186955...d737:a941f37256bb87fe903353213f0dee77ada190db
His install video:
(Just to note, you no longer need to solder those connections shown in the video, the seller does that for you and all that you have to do is click the harness into the existing connections. I was thrilled with this!)
The tldr version of this: I absolutely love this auto dimming mirror and wire harness kit, it’s worth the $176 with taxes/shipping and it’s something that most people can install with minimal experience.
My biggest pet peeve was Ford omitting these features from the Maverick, especially after jacking up the price on it recently. Thankfully this kit here with the instructions provided allows for someone to add on the auto dimming mirror and built in garage doors openers that looks/functions as if it was installed at the factory.
Install was relatively easy, the only tools you need really are the plastic pry tools for removing interior trim panels, I got mine on Amazon for $10 (https://www.amazon.com/dp/B01L8GHB7O?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1). I only needed the pry tool for the black plastic trim piece mounted to the windshield, the overhead light panel/sunglass holder can be removed by opening the sunglasses holder compartment, hooking your hand on the inside and pulling down with a little force.
I would also recommend having a drill with a 1/4ā€ bit, in the video the man used wire cutters to make a channel but I saw elsewhere someone running a drill bit on its side against the plastic and it makes a much cleaner cut that looks like it’s there by design, you won’t see it after everything is up but I am a bit of a stickler about things looking nice.
Just to note, that black panel on the windshield has some plastic cable that prevents it from falling, I couldn’t figure out how to remove it without damaging it so I left it on while I drilled that channel, then the panel fell off the wire, I couldn’t get the cable back into it’s mount so I left it off when I reattached the panel.
After connecting the wire harness and mirror everything powered up, my overhead lights continued to work and I didn’t get any electrical issues or alerts from the car. The mirror continues to stay on after locking the car for 15-20 minutes, then powers off when accessory power goes off. I don’t know if the Homelink garage door opener buttons are still powered after this point, as I know an always hot wire exist up there but I don’t know if the harness is setup to take advantage of that. I’m fine with the Homelink being completely powered down with the car off as I often park on the side of my garage.
After that, getting the Homelink/garage door openers programmed to my equipment took about 5 minutes. I used the wireless remotes to program them, as that took less effort compared to getting to my garage door openers learn buttons. I had to calibrate the compass manually, you have to set what zone you are in North America using the map in the instructions and then drive around in circles 3 times at below 5 MPH before the display goes from ā€œCā€ for calibration to displaying which direction your facing. I had some issues here, I did it 6 times in one spot and it wouldn’t calibrate, I changed to a bigger parking lot and did it 3 times, then it worked. This parking lot had less trees overhead and was wider, I am unsure if this mirror tells your direction from GPS or has a magnetic sensor that picks up the Earthā€˜s magnetic field.
After that I tested the auto dimming with a flash light and the mirror dimmed. So now it’s fully setup, I am happy with the function and look of it, looking at it from inside and outside the windshield it looks like Ford put it there from the factory. Lastly, the seller gave you the option of a frameless auto dimming mirror with the Homelink buttons tucked under it, I didn’t like how it looked since it seemed like it had a gaudy silver finish and cost more money. However, the seller makes wiring harnesses with additional connectors for other accessories, I paid the extra $12 to get the female USB port in case I decide to ever get a camera or radar detector, I might never use it but it’s there under the plastic trim if I decide I need it, the female USB also glows red from the socket to show it’s powered.
Thats it, I am quite happy with how this turned out and added features back that I expected to be standard relatively cheaply and easily.
Ford Maverick Auto-Dimming Mirror with Homelink Garage Door Opener Installed! DIY how-to tutorial Screenshot_20250803-164527_Gallery
notfast
Los Angeles CA
I didn't see much a point in auto-dimming mirrors. Figured my two-way manual mirror was good enough. Then I had a car that came with one, and saw (or rather, didn't) see the light. If you use your rearview mirror, I'd suggest it as a nice quality-of-life upgrade.
As for me, I've always had trucks that had something obstructing the view out the back, like a headache rack, tool box, or topper. Rearview mirrors aren't legally required on trucks anyway, so I just yank them off.
mstrbill
Marana,AZ
2024 Lariat FX4, 2017 Beetle Convertible
You should be able to test it, by letting it time-out. Then open the door and see if the Homelink buttons are active. I am guessing they are always powered.
chrisofpa
chrisofpa
Great tutorial, is it any larger than the stock mirror though?
The width and height of the mirror is the same but it is thicker front to back due to the electronics inside. I did notice though the auto dimming mirror doesn't have as much articulation in its mount compared to the stock mirror, it still has plenty of articulation to adjust the mirror to your liking but I noticed when installing it I couldn't move it as far to get to the locking screw to remove it from the windshield.
I also noticed I couldn't take the new mirror on/off the windshield without removing that black plastic trim piece that's on the windshield. Once installed though these are non-issues IMO.
chrisofpa
chrisofpa
When I bought my first car 15 years ago I got spoiled by the feature, that and having the Homelink, so whenever I drove a vehicle without it I really missed the feature. I also do a lot of driving at night so I really noticed the lack of the feature. In fact this is my first pick up. I had a coupe, a sedan and a hatchback before this.
chrisofpa
chrisofpa
The thing is soon as you open the door, the accessory power comes back and powers on the mirror. Guess I could sit in the car and wait for the accessory power to turn off, I might try that one day.
Onceaneagle
Walt
Sedgwick, Kansas
F150
Ford built an inexpensive and very nice truck that I hope to acquire in early 2026, yet with what is now MSRP for a Lariat or Tremor the autodim mirror and a left side assist handle should be included in those packages. I am a geezer, yes, and have trouble getting in and out of vehicles but moving down in size from an F150 Lariat should still retain some of those comforts. I'm not asking for cooled seats like I have now. If anyone knows how to install a column mounted grab handle on the driver's side, I would appreciate instructions and parts, besides superglue or duck tape!
Jroberts302s
Josh
Nashville, Tn
2023 maverick,2012,fusion, 2014 focus,2003 cobra
Thanks for the write up! I will be doing this soon!
Onceaneagle
Walt
Sedgwick, Kansas
F150
His install video:
Is this mirror kit available elsewhere for those of us who do not use PayPal?
chrisofpa
chrisofpa
chrisofpa
chrisofpa
Couldn't agree more, I believe now that the upper trims moved up in price a considerable amount, we should be getting features like that standard. This feature should be available even on the lower trims.
Onceaneagle
Walt
Sedgwick, Kansas
F150
Hawley? Wow. I was born in Carbondale. My Aunt was a Seeley and with my Uncle owned Seeley's Landing. Beautiful lake. Still have relatives all over the area. Small world.
jcnnjc
Newnan Ga
Fiesta ST , Alto Blue Maverick awd fx4
Thanks for the info, I didn’t know I needed this until I bought a 2025 Mazda MX5 Miata.
I love the home link mirror it has, I will be ordering one tonight.
Aleks
Aleks
West Coast
Nice job! I'll be doing mine soon.
I also have one for sale if anyone wants it (I decided to go frameless but its way more expensive) and I'm trying to break even on this one ($80 shipped). I have a wiring harness made up and labeled and included... It's homelink v5, which is the latest version of homelink, no compass.
I fried the first mirror trying to get the correct pinout :facepalm: and had to buy a new one so avoid my mistake.
Ford Maverick Auto-Dimming Mirror with Homelink Garage Door Opener Installed! DIY how-to tutorial 1
Ford Maverick Auto-Dimming Mirror with Homelink Garage Door Opener Installed! DIY how-to tutorial 2
