What format are the music files? If they are an apple format like .aac they will not play since those are a drm protected format. If they are .m4a those are not drm protected but Ford audio may not support them period.Formatted as fat32. Exported library to drive. PC can see files. Maverick says indexing-complete then says no media on drive.
Both actuallyAre you trying to run music that you've bought through Apple Music, or music from an Apple Music subscription account? Not sure if the latter would work because of copyright protection.
What or where did you grab the song from to drag it. I have found the itl files, did copy/paste. Tried exporting from library.I have this flash drive with about 25gigs of music and it works great! I just did the drag and drop from iTunes on my Mac.
You are correct. I need software to remove the DRM.What format are the music files? If they are an apple format like .aac they will not play since those are a drm protected format. If they are .m4a those are not drm protected but Ford audio may not support them period.
My apologies… I was referencing my personal music library. I play Apple Music with my phone plugged in to the USB C.What or where did you grab the song from to drag it. I have found the itl files, did copy/paste. Tried exporting from library.
You'll have to convert them also besides removing the drm. If they are lossy then converting to mp3 will work. If lossless then to flac.You are correct. I need software to remove the DRM.
Love the compact size. Does this flash drive have a little blinking light as it operates? That drives me nuts!I have this flash drive with about 25gigs of music and it works great! I just did the drag and drop from iTunes on my Mac.
